Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 01-10-2007, 08:40 PM   #1
SANDBLASTING & REMODELING
plazaman's Avatar
Trade: SODA BLASTING & REMODELING
Screen Sanding & Moisture Cure Finish
Guys,
Customer of mine has regularly maintained his floor with screen sanding and moisture cure finsh twice a year. He cannot get a ahold of his contractor and asked if i could do the job.
I have refinished many floors and screen sanded, but none with the moisture cure finish.'
From what i understand, its supposed to be a highly durable finish.
Someone mentioned to me that the application is much more difficult than the tradional finishes, is this true? How different can the process be?
What are my alternatives for finishes, i need something very durable, a finish to withstand commercial traffic everyday (store)
Thanks
www.perfectocorp.com
plazaman is offline   Reply With Quote
Old 01-14-2007, 03:38 PM   #2
Trade: tile contractor
Moisture cure is very durable ,good for commercial .As far as difficulty to apply it depends on your experiance- syntecos mc can be rolled for me its the easiest and produces the best looking finish. justin p.s. this stuff is very nasty to breath use resperators and a tyvek suit and gloves.
justin savage is offline   Reply With Quote
Old 01-28-2007, 12:48 AM   #3
plazaman's Avatar
how is the application different from a the old lambs wool applicator ?
Old 01-28-2007, 02:40 PM   #4
A lambs wool tends to push a puddle of finish across the floor- sometimes causing the dulling agents in satin and semi satin finishes to not flow properly causing an inconsistant sheen, the weight of the lambs wool app.causing some of this. Rolling finishes that are designed to be rolled eliminate this because rollers apply the finish. hope i explained this well enough. justin
Sticky finish...Boy could I use some advice Uuber_Framer Flooring 11 10-26-2007 03:41 PM
Drywall Sanding Sponges? Abrasive Dan Drywall 6 06-14-2007 04:35 PM
Stripping old deck finish joedonuts Painting & Finish Work 26 06-09-2007 10:34 PM
Can You Help Identify This Finish? Richie-C Painting & Finish Work 10 06-07-2006 08:34 PM
metal railing finish failed problem? a68cudas Painting & Finish Work 9 06-06-2006 02:37 AM
