Trade: tile contractor
Saw Blade Size
This may be an uneducated question, so humor me.
Are their any pro's and cons to using an 8" blade on a 10" saw as long as it will still reach the tile to cut clear through? |
Trade: Flooring
Re: Saw Blade Size
Theres nothing wrong with it at all. I actually use 7 1/4" Circular saw blades in my 10" table saw. It really saves a lot of money and i like it better because it has a small kerf. So its basically the same thing with the tile saw. Doesnt work in chop saw / miter saws.
Re: Saw Blade Size
A 10" blade will cut faster at the same RPM due to a higher blade surface speed.
An 8" blade has a circumference of about 25". At 1750 RPM the cutting surface moves about 3,650 ft. With a 10" (31.5 c) at the same speed exposes about 4,600 ft., about a 20% increase in productivity.
Trade: Home Improvement/Remodeling
Re: Saw Blade Size
Will it also reach the reservoir? (I assume we're discussing a wet saw?)
| Help w/ gas pipe size calc | mdshunk | Plumbing | 45 | 01-29-2009 05:25 PM |
| Decent size deck in currently in progress | andy builds | Carpentry Picture Post | 16 | 10-26-2008 08:54 PM |
| XLM Decking -what blade do I need? | soilman | Decks & Fencing | 9 | 05-03-2008 06:16 PM |
| Best Utility Knife | Journeyman T | Tools & Equipment | 48 | 02-20-2008 08:54 PM |
| So what diamond blade DO you use? | lukachuki | Masonry | 15 | 01-03-2007 01:24 PM |
