Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 01-25-2007, 09:50 AM   #1
Trade: drywall, finishing, painting
sanding a wood floor?
Got to get this done at my house, pulled up the old carpet that was a mess, and found a great looking hardwood floor, but it needs refinished. I've seen those sanders but they make a dusty mess, and i dont want the dust althrough the house, what other options do i have? the room is 16x20.
daworz is offline   Reply With Quote
Old 01-25-2007, 10:16 AM   #2
Suck it up, or shut up
I refinished 3 large rooms a week before xmas. I was sanding for about 12 hours starting with 20grt all the way to 120grt.
I taped the doors and put towels down along the bottoms I also vac. (shop vac with a hepa filter) floor when ever the sawdust started to build up. I still had some dust, but it wasn't realy that bad. one thing I wish I had done was tape off my kitchen cabinets (forgot) I can still find a dish here and there that is a little dusty.
rservices is offline   Reply With Quote
Old 01-25-2007, 10:37 AM   #3
Sanding floors
Yes i did consider hanging platic between rooms, the only problem is that this is a middle room and is between the great room and Kitchen, I figured that i could do it and get all the sanding done then remove the platic time for sanding depends on me and how hard and late iam willing too work, as for the finshing i would'nt need the platic? Thanks for the reply! I had saw on a DIY show where they used a sander that left No dust, but i would guess that would coast a pretty penny to owne or rent if you could even find 1.
Old 01-25-2007, 11:54 AM   #4
The rooms I did were also in the center of the house. If at all pssible do it all at once. Sand then stain, The more traffic that happens when you wait will just make matters worse.
I had all of the rooms sanded, and let my cats down for a short time, and ended up haveing to re-vac for an hour due to cat hair.
It's worth the short term sacrifces to have it done right and over.
kick everyone out for 24 hours, kennel the pets, buy some new CD's and rock and roll
Old 01-25-2007, 01:53 PM   #5
Sanding Floors
Ok, Its on I wil start as soon as i find a place where i can rent a drum sander? I live where the cows roam? So i have too make it down too a rent-all store. It wil take it down to the bare wood so i alos have too pick a new stain out and the probably a cuople coats of Clear!
Old 01-26-2007, 07:42 AM   #6
Trade: Finish carpenter
Sanding floors
Remember to empty the dust bag OFTEN.
mack9110000 is online now   Reply With Quote
2 x 4 wood floor trusses- Help sawit General Discussion 12 07-20-2007 09:55 PM
Laminate Wood Flooring Over An Old Garage Floor mjm0073 Flooring 1 01-30-2007 10:42 PM
Wood floor 2" or 4" drivewizard Flooring 23 12-24-2006 12:06 AM
Cutting old wood floor lizzydog Flooring 18 10-22-2006 09:22 PM
2X6 Wood Floor sblade46 Flooring 20 04-02-2006 08:16 AM
