Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 02-24-2009, 08:00 AM   #1
Trade: HVAC And Zone control Systems
Sanding No. 2 white oak and the rustic look..
Ok, I am slowly becoming aware that the no. 2 white oak 3 and 1/4 inch plank going down in our cabin may or can be done differently for a rustic look-now sanding is the question. I am about ready to sand, and we have decided to not fill most of the imperfections. Do we need to sand this floor to the same extent that one would for a formal living room using clear oak? Do some not sand at all? Are some slightly out of level edges ok? We will be staining an using poly. Thanks for the help!
Texwing is offline   Reply With Quote
Old 02-24-2009, 04:50 PM   #2
the big 12 inch's Avatar
Trade: hardwood floor contractor 28 yrs.
If you are planning to sand them yourself,the best and ONLY advice you need is.....DON'T DO IT!!!.I don't care how smart you are.I don't care if you can build a rocket with your eyes closed!!.It takes years of experience to be able to sand hardwood floors without ruining them.Even if you had the right equipment(which you cannot rent)you don't have a clue as how to use it...Anyone that tells you any different is doing you no favor...good luck...I have put in the same thing for several customers over the years and just putting the stain over the unsanded wood and 3 good coats of poly makes for a nice rustic looking floor.I usually stain them a pretty dark color or a grey-wash stain...
the big 12 inch is offline   Reply With Quote
Old 02-24-2009, 10:19 PM   #3
Knowledge Factory
Floordude's Avatar
Go rent a U-sander or a 220 version called the SuperBee, and you cannot possibly ruin the floors sanding with either of those sanding machines. They are not as aggressive.
http://www.AustinFloorguy.com
Floordude is offline   Reply With Quote
Old 02-24-2009, 10:46 PM   #4
Trade: Painting, flooring
I watched a homeowner try and refinish their home once. I didn't believe that a human being could actually spontaneously combust until that point.
sparehair is offline   Reply With Quote
Old 02-25-2009, 10:01 PM   #5
I have witnessed this spectacle MANY times over the years...
Old 02-25-2009, 11:03 PM   #6
Mellison's Avatar
Trade: Home Improvement General Contractor
Great advice.
A new oak floor that is un sanded before the poly is applied will give a very nice rustic look.
Absolutely perfect for a cabin.
"Enjoy Every Sandwich" Warren Zevon
Mellison is offline   Reply With Quote
