Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 02-23-2009, 10:10 PM   #41
This ain't my first rodeo
loneframer's Avatar
Trade: residential framing/general carpentry
The house will talk to you alright,
but someone there has to know
what she's sayin'.
Yessir, I understand houses much better than I did my ex-wife. Of course my ex moaned and groaned louder and more often.
loneframer is offline   Reply With Quote
Old 02-23-2009, 10:15 PM   #42
Starving Tile Artist
wizendwizard's Avatar
Trade: Carpentry, Flooring & (UGLY) Tile installs.
Send a message via Yahoo to wizendwizard
Originally Posted by rbsremodeling View Post
I would try to contact the insurance company. Like I mentioned they might cover the damages. She has nothing to loose by trying
I'm going to call her tomorrow and let her know that we have some possible solutions. We'll see what she has to say about tasking this further.
"If you start the grout process over, you too could use sparkly grout!"
Columbia SC Tile Installer
http://www.adepthomerepair.com
Adept Home Repair Services
wizendwizard is offline   Reply With Quote
Old 02-23-2009, 10:18 PM   #43
Going back to something Aggie mentioned, should I really attach joist hangers BEFORE we get this beam jacked up?
I know what i'm thinking the answer is but I wil wait and see!
Old 02-23-2009, 10:20 PM   #44
I used to deal with this from time ti time. I had a friend who did house jacking and moving. I would try to find some one like that with some long heavy duty steal. Then you can slide in the two beams parallel to the main and jack them up from outside the foundation. Do this slowly over a few days to minimize the shock to the structure. Than once 1/8th or so above desired hight you can do whatever you need to replace or repair the main and let the weight back down. I would recomend some old railroad jacks as they are strong, safe, and mechanical (cant blow a seal). Good Luck
JBMagi is offline   Reply With Quote
Old 02-23-2009, 10:26 PM   #45
That will let it all mve together.
Two more beams under the joist
are going to seriously cut into
the spacious 13˝" headroom.
neolitic is offline   Reply With Quote
Old 02-23-2009, 10:34 PM   #46
The key to this project is to not do further damage to the home in any way. The I beam trick does work for house movers. It is not practicle in this situation.
This goes the same for ripping the flooring out. These things just are NOT going to happen.
If I have to excavate the whole underside of the house out with camp shovels I will get this done without doing damage to the floors or foundation.
On that note, I'm going to bed. Have a good night all and Thanks again.
Old 02-23-2009, 11:28 PM   #47
cleveman's Avatar
Trade: custom home building
Good morning!
I'll post it again. Hire a guy to raise the structure. Drive under it with an excavator. You'll have about 6' of headroom then. They can raise the house up on cribbing.
Next, call some guys to pour footings and basement walls.
Step 3-lower the structure. It will come back down the same as it went up.
Now you have a basement under the house. You can frame a wall or whatever under the center beam.
I'm thinking $20K to do this. And you'll have a basement underneath when you're done, can you dig it?
cleveman is offline   Reply With Quote
Old 02-24-2009, 05:53 AM   #48
Originally Posted by cleveman View Post
Good morning!
All that for 20 grand??
I think you have all the advice you really need. The information is ALL here. It all depends on what her budget is. I have done the same thing numerous times as most of the houses that I work on are 100 years old or older. If your shooting for perfect, you my have a long way to go. I also agree with using the railroad (or bugle) jacks if you can find them. If you can get a laser down there and find out exactly where it's the worst and how far you have to go before even starting, would also be a help.
'The trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.' - Ronald Reagan
PA woodbutcher is offline   Reply With Quote
Old 02-24-2009, 08:51 AM   #49
Let's see .....this is a center bearing house so above those piers is likely a wall thats bears the weight of the attic floor or second floor right? Is there a large opening pass through on the main floor? Is it possible there is a point load that lands right where the dam sag is? Sometime ya need to see how it got this far.
tom m is online now   Reply With Quote
Old 02-24-2009, 09:26 AM   #50
Trade: renovator
Uh - I'm surprised not to find anywhere in this thread mention of the earth the ceenter beam piers are sitting on. A 60-year old house with 2-inches of settling? I know, no footings, but still, those piers are what, 18" x 18"? Practically a footing in themeselves. I would think step one is check the soil before deciding how big the footings for new piers would be - maybe something's up.
Next - just how critical is it that the floors be rendered perfectly true? Millions of older homes have some sag to their floors and people live in them just fine every day. What's really important is not so much the current amount of sag, but stopping future sag that may become damaging to the structure. But if muscling the house back to perfect true is going to be a major pain and cost, or cause damage, maybe just jacking back to 1-inch of sag and planing a few door bottoms will suffice. Sometimes perfection is our enemy.
bob_cntrctr is offline   Reply With Quote
Old 02-24-2009, 09:31 AM   #51
I assumed the floor was being ripped out. If this is not the case then my beams would make any work impossible. Maybe try and slide under and jack the beam directly after joist hanging as some of the other guys said. Or maybe you could rent one of those tunneling machines I see on tv bore under the house then work on it.
http://www.bullhomeimprovement.com
Old 02-24-2009, 01:47 PM   #52
There are exterior and interior renderings on this thread that shows where the walls are in comparison to the joist underneath. All angles are from the same POV.
We are not looking for perfectly true floors. I will work up a rendering to show how the kitchen looks and the effect it is having on the HO's life.
Now if you will notice the yellow marking.
That indicates the down angle we are dealing with on the interior.
This shows that the outer beams of the foundation are still level.
It also shows that the center beam has sagged 2" at the point where the 4 rooms meet.
This is why I said that the center beam hold all of the weight of the house.
Old 02-24-2009, 04:56 PM   #53
Trade: Framing
Sounds like you don't want to fix the actual sag, just make the floor look nice.
Or did I miss something?
fixitpete is offline   Reply With Quote
Old 02-24-2009, 10:15 PM   #54
I want to fix the sag, I'm not contracted to fix the sag. I was contracted to fix the wavey floors. This has been done. The purpose of my posting here was to gather needed information from other professionals in order to present that information to my customer for future repair options.
I sold myself to her on the repair of wavey floors. Now I am prepared to offer her options for further repairs. This is a business for the future, not the now.
Old 02-25-2009, 07:51 AM   #55
Trade: Framing
Fair enough. I don't know how you can fix the floor without fixing the structure... unless you think, for sure, that the house isn't going to move anymore... then I guess that would sort of be called "fixing the wavy floor".
My bad.
Old 03-02-2009, 06:44 PM   #56
Professiona Instigator
rbsremodeling's Avatar
Trade: Design Build Remodeling Contractor Washington, DC
Welp
I bidded this exact same job to day.
If i get it I will take pics and video as we go along. The house is fawked up.
12 contractors came out and all either refused to bid or did not return calls on the job
Being an idiot frees a man from having to live up to others peoples expectations.
rbsremodeling is offline   Reply With Quote
Old 03-02-2009, 07:29 PM   #57
Dapper Crapper
WarnerConstInc.'s Avatar
Trade: I am not your bank!!
Can I come play with you on that one Rory, I love moving around beams in old houses, its fun.
WarnerConstInc. is offline   Reply With Quote
Old 03-02-2009, 07:34 PM   #58
I am going to go out with my guys and the engineer before I start. if anyone looks at me iffy I am out of there.
This will be the hardest one I have done to date, its bad. Access is nil and the beam is gone.
House is worth about a 1Mil
Your more than welcome to I'd pay you to help, keep your fingers crossed
Old 03-02-2009, 07:46 PM   #59
We'll tell your next of kin
what a great guy you were!
Or we could be honest
if you'd rather?
Old 03-02-2009, 07:55 PM   #60
if you'd rather?
After 38 years on this planet I think they know the truth
Tapping into Galvanized Water Main mtbmac Landscaping 2 09-06-2008 04:44 PM
main trips pat c Electrical 13 08-20-2008 06:05 AM
Updating main beam in century-home: end. bob_cntrctr Framing 8 02-07-2008 04:04 PM
Main v.s. Load 2 Gang Meter Bubbles Electrical 5 10-05-2007 07:05 PM
Main beam sagging 1/2 inch? AllGoNoShow Construction 10 10-12-2006 07:20 PM
