From Rot To Tile In Japanese Bath
Old 06-06-2005, 04:15 PM   #1
timberframer's Avatar
Trade: timber framing, sawmilling
hello, i am a timber framer by trade but have started into japanese style bath houses which brings me here it is an older home: on the joists sits 2x12 sub floor and on it sits 3/8" plywood then linoleum. Lino is up and out, there was a bit of rot into the plywood and 2x12. The 2x12 runs part under the wall and is 80 there so i feel i can keep it and add some kind of fill/patch to level it off, then patch in the 3/4" plywood. Questions: what do you generally use for patch material, one suggested 'Poly Underlay Plus Floor Leveler', it is cement based? With the 2x12 subfloor and 3/8" plywood, do i put my membrane/liner on this, then mud floor sloping to drain at about 1 degree, then thinset, then tile? OR does the floor need more underlay? it seems pretty stable at this point. kind thanks, michael hollihn, prana timber frames
timberframer is offline
Old 06-06-2005, 09:47 PM   #2
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
Re: From Rot To Tile In Japanese Bath
maybe too much deflection if your plywood is not at least a total of 1 1/8 thick.
Either that or install concrete board on top of the plywood subfloor.
Floorwizard is offline
quarry tile to quarry tile rservices Flooring 8 01-15-2010 12:37 AM
Learning to install Floor and Wall Tile!! TurnkeyConst Flooring 25 01-17-2008 08:01 PM
pricing 1/2 bath ceramic tile job 72chevy4x4 Flooring 7 10-08-2006 03:10 PM
Got some design ideas for tile wainscoting? Mike Finley Ceramic & Stone Tile 2 05-09-2006 10:05 AM
Cutting Existing Tile. kpikul Remodeling 16 02-05-2006 12:30 AM
