Originally Posted by res0zvle@gmail.
Hey Guys
I need to install Racedeck flooring (12x12 plastic interlocking floating tiles) on a garage floor. I'd like to use an underlayment to avoid some of the clacking noises heard while walking on it. Does anyone know whether the roofing felt will hold up considering that the garage floor will get wet (as will the roofing felt) over time? Thanks for the help!
Jim
Jim, you might also consider an .045 or .060 rubber membrane instead, either loose laid or fully adhered. This would provide additional sound deadening, not to mention a slight cushion feeling as well.
