Trade: Custom Home Remodeling 30+ yrs
RESURFACING TILE? Ugh...
Here goes,
I don't really want to resurface this guys tile but his logic seems to make a bit of sense. 3 Walls and the Floor 7'H 3'W are tiled in a shower. and the Kitchen Sink. It's a rental so HO doesn't want to re-tile the shower. HO said he just wants it resurfaced. I'll probably just remove the sink to resurface it but I bet it wasn't removed before. He mentioned at the end that they had both been resurfaced before, is there a safe way to remove the previous resurfacing or should I try and epoxy putty any chips in the previous job. (PUTTY RECOMMENDATIONS?!) I've used these KITS before so I know the process, If there is anyone who does this a lot, any recommendations would be appreciated. Of course I'm asking in advance and headed off to research it now. Thanks! Last edited by MZ-HANDYMAN; 08-05-2009 at 01:53 PM. |
I like Green things
Re: RESURFACING TILE? Ugh...
Yeah, its called bath-fitter, should be right up your alley.
Bath-fitter...No can do...
HO wants an El-Cheapo solution... I'm planning to refinish it... Like this... Sand with 1000 grit wet/dry (Not the recommended steel wool) then Clean it with KRUD KUTTER then rinse and do it again 3 times total then wipe it down with mineral spirits then wipe with tack rags and begin spraying it with epoxy paint at 60 lbs through my conventional sprayer. Looking for a better solution along the same lines or a Yup go do it! Thanks anyway (I think!) |
#4 | |
Trade: Perfessional Contracter
Re: RESURFACING TILE? Ugh...Quote:
No offense intended MZ but how in the hell do you let yourself get talked into these jobs?? Another thread doomed from the OP. Where's a Mod - may as well close it now and save us all a hangover. |
#5 | |
Doofenshmirtz Evil Inc.
![]() Believe me I am as hard up for work as the next guy.But I'm not going to do something unless I have done it before and can give professional results...Call me crazy...
in texas with framing and cornish people will do it for 3.00 a foot. What do yall think about that? Just laber |
| The Following 2 Users Say Thank You to JumboJack For This Useful Post: | angus242 (08-05-2009), ChainsawCharlie (08-06-2009) |
#6 | |
I know what I'm doing and have done a few before, Just looking for tips on improving the results! I did the tile work too. Last edited by MZ-HANDYMAN; 08-05-2009 at 11:01 PM. |
Seems to me you need help on just about every job you do....just sayin'
Re: RESURFACING TILE? Ugh... |
Back from the dead...
Trade: Paperhanger/Painter
For the love of God, either quit reporting these posts, or just plain quit posting.
As you said, give it a rest already. TIA |
| The Following User Says Thank You to ProWallGuy For This Useful Post: | AtlanticWBConst (08-06-2009) |
#10 | |
Its all ball bearings
Trade: Tile
I agree with someone's post. That's my right. Doesn't make me a moron. Your post is a bit confusing by saying "I've used these KITS before so I know the process" but then ask for advice about the process. Remember, you're asking for FREE advice. You can't expect people to always answer all of your questions when it comes to a job you are making money on. When I run into a situation I'm not sure of how to complete, I hire someone to do it for me. If I get a chance, I'll then pick their brain to possibly further educate myself. Watching someone do something is a much better lesson then asking someone via the internet. I think that's some pretty good advice. Although, I'm probably on the infamous block list now anyway. ![]() Good luck with your project.
Angus L+M+O+P=C ![]() "Promise only what you can deliver. Then deliver more than you promise" |
#11 | |
Do you know how to refinish a tub or sink? I'd like to hear your process. |
I like Green things
I buy new one's. That crap dont last man.
Warner,
I would love to tear the whole thing out and do it right, It's a rental property and the HO just wants me to resurface the shower tile. I just wanted to know if anyone uses the method I use or if they have a better way that would improve my results. Thanks |
I like Green things
I know it is a rental. You are thinking way too hard for a pos rental.
bathroom guru
As well as doing complete bathroom renovations, I have owned 2 reglazing business's. Was in the business for about 15 years before I finally came to my senses and got out of it.
Your process is all wrong. You will have issues. Not trying to be a pr**k, just want to honestly tell you - do not try a job like this yourself. If however you are hell bent, you need to buy a HVLP system, an air extraction unit (with explosion proof motor), a fresh air system, the correct preparation chemicals, the proper thinners, etc..... And, the "kits" you buy are crap. You also need a special rider on your insurance policy when you are spraying materials in a residence. Finally, Did I mention that stripping an old finish off of existing tubs and tile can be a lethal process?? 2nd Finally, Don't even bother with the kitchen sink - it will fail |
| The Following User Says Thank You to jarvis design For This Useful Post: | MZ-HANDYMAN (08-06-2009) |
I do work in an apartment complex and have seen some of the bathroom's after a bit of wear and tear and they look crappy. The finish also does not have any luster; that could be the original application, age or cleaning techniques between tenants. Either way, I understand you wanting to get the job, but how about a cheapo $80 plastic surround which is glued to the existing tile?
Why does the owner want this done? to update the looks for functionality (hide damage)? As far as the comments go, you're gong to have to get a thick skin and wade through comments because they will be plentiful given the situation, but you will likely find some good tips...mine is above :-) |
| The Following User Says Thank You to 72chevy4x4 For This Useful Post: | MZ-HANDYMAN (08-06-2009) |
#17 | |
I like Green things
#18 |
WC,
Yeah but in my head if I think like that then I qualify for the "HACK" title. I treat a Low Housing project like it was a multimillion dollar home. If I can't do it right or do it better than expected then why do it. I have a thirst for knowlege and there is always a better way no matter how good you are. A rookie in your field could pull a suggestion out of the air and solve a problem that was costing you time and money for the past 20 years. OFF TOPIC: When I got into tile work The guys I was learning from were cutting 1" tiles with a diamond blade and a mini grinder. I simply took a 14"x14" piece of backer board and layed it on the saws slide then set the blade down where it barely touched the backer board and cut the sheet of 1" tiles like it was a full tile. One of the guys had been cutting those tiles for 8 years with a mini grinder along the edge of his grout float (All his floats had concave sides). He asked me how long I've been doing tile and was surprised to learn I'd never done it before. BACK ON TOPIC: Little things like that are why I ask if anyone has a better way or suggestion for a different product. Last edited by MZ-HANDYMAN; 08-06-2009 at 12:29 AM. |
#19 |
#20 | |
I like Green things
What size shoe do you wear? That is why people give you ****. |
| Tags |
kit, resurfacing, shower, sink, tile ![]() |
| Tile Over Gypcrete | Golden Rule | Ceramic & Stone Tile | 6 | 11-26-2010 04:00 PM |
| Removing tile that is set under base cabinets.. | bujaly | Flooring | 43 | 03-13-2010 05:15 PM |
| Commercial Ceramic tile on concrete slab removal | TD40 | Ceramic & Stone Tile | 4 | 05-27-2009 05:02 PM |
| Tile over Tile | fireguy | Flooring | 3 | 02-26-2009 11:36 PM |
| information on fixing a bad tile job | bford | General Discussion | 4 | 09-30-2008 07:44 AM |
