Restaurant Grout Cleaning
Old 03-08-2008, 01:55 PM   #1
Suck it up, or shut up
rservices's Avatar
Can anyone recommend a effective way to clean the grout in a restaurant (large build up of grease and dirt) cleaners, or chemicals (maybe napon)
I have a cold water pressure washer, and I know that a hot one would work well but I don't want to buy one at this time.
rservices is offline
Old 03-08-2008, 02:45 PM   #2
JonM's Avatar
Re: Restaurant Grout Cleaning
Rent one...or try bleach
JonM is offline
Old 03-08-2008, 02:47 PM   #3
SelfContract's Avatar
Trade: Home Remodeling
CloroX abrasive... scratch hard & spray on.. etc.
SelfContract is offline
Old 03-08-2008, 02:51 PM   #4
fez-head's Avatar
Trade: Contractor/ Business Owner/ Entrepreneur
I would sub it out to a carpet cleaner that also does tile cleaning or a PW company with a reclaim system.
fez-head is offline
Old 03-08-2008, 03:47 PM   #5
Tile Contractor
Bud Cline's Avatar
Power washers will ruin the grout and take it out completely in some cases.
Bud Cline is offline
Old 03-08-2008, 04:03 PM   #6
fez-head's Avatar
I guess it would in the hands of the inexperienced. Hot water and a surface cleaner with reclaim does just fine at 900 PSI or less.
fez-head is offline
Old 03-08-2008, 08:07 PM   #7
tile contractor
Bill_Vincent's Avatar
Trade: Ceramic and stone tile contractor
Send a message via ICQ to Bill_Vincent Send a message via MSN to Bill_Vincent
TSP (Tri-sodium phosphate). Best damn greasecutter around. Use it with a scrub brush, and wet vac, and then mop with clean hot water.
"Whether you think you can, or you think you can't, you're probably right."
http://www.creativeceramicandmarble.com
Bill_Vincent is offline
Old 03-09-2008, 01:13 AM   #8
Knowledge Factory
Floordude's Avatar
Steam clean it...
http://www.save-now.com/grout/GROUT-...R-CLEANING.htm
http://www.AustinFloorguy.com
Floordude is offline
Old 03-12-2008, 01:35 AM   #9
Where's the Grease
Michigan Exhaust's Avatar
Trade: Michigan Restaurant Vent a Hood Cleaning Company
How much of this tile are you cleaning?
Under the sinks, near grease traps, and around the cooking line?
Or are you just doing the main paths of grout and tile?
Michigan Exhaust Cleaning
Your First Step in Restaurant Duct Fire Prevention
http://www.michiganhoodcleaning.com
Dave Ott 800-861-6475
Michigan Exhaust is offline
Old 03-12-2008, 08:17 AM   #10
rservices's Avatar
I'm doing about 600sq/ft.
Theres a lot of tile replacement and re-grouting also. I thought I would do that work 1st (their getting water in the basement) the after it cures I thought I would use some heavy duty degreasers and a side by side scrubber (brush) rinse and vac.
Several people have mentioned TSP but wont this leave the floors cloudy?
Old 03-12-2008, 08:34 AM   #11
tile contractor
Not if you hit it with clear water and a brush afterward and suck it up wiht a wet vac.
Old 03-12-2008, 09:24 AM   #12
fez-head's Avatar
Just curious how are you dealing with the greasy substrate under the loose kitchen tile? We have found that a diamond cup blade on the grinder works very well. A box is set over the individual tile with a shop vac hose inside to controll dust.
There was alsways so much grease down in the pores of the concrete that removing the top mil. was the only way to get a good bond and make our repairs last. I'm always looking for better ways of dealing with filthy kitchen repair work.
fez-head is offline
Old 03-12-2008, 11:36 AM   #13
Tile Contractor
Bud Cline's Avatar
So then......what you are saying is that our local KFC shouldn't be using that 3500psi machine they use for cleaning their floors on a daily basis???
H-m-m-m-m-m! Imagine that?
That's' OK...regrouting is fun!
Old 03-12-2008, 01:58 PM   #14
fez-head's Avatar
I love it when the Flunkies bring out their big - bad electric 3,500psi 2.5 gpm cold water machine That means along with grout replacement it wont be long at all until we are replacing base cove, lower drywall and FRP board, and usualy some peeling paint as well.
We have a love/ hate relationship with the Flunkies because they sure keep us busy
fez-head is offline
Old 03-12-2008, 03:59 PM   #15
Starving Tile Artist
wizendwizard's Avatar
Trade: Carpentry, Flooring & (UGLY) Tile installs.
Send a message via Yahoo to wizendwizard
TSP is the chit!!!!
"If you start the grout process over, you too could use sparkly grout!"
There is no such thing as an illegal immigrant, they are either illegal or immigrants.
I'm Retired, or a student, don't really know anymore.
wizendwizard is offline
Old 03-12-2008, 05:16 PM   #16
tile contractor
WHy go thru all that with the box, when they make grinders already set of for just what you're doing? This is the one I have, but they also have 4 and 5" machines:
Old 03-12-2008, 09:11 PM   #17
rservices's Avatar
I use the same surface grinder when needed, with a little water on the floor there is no dust problems. Also in the restaurants they have specific chemicals for food grease they work very well.
I deal with a lot of grease issues, I've had floors with a handful of loose or cracked tile that end up being 6 to 10 sq/ft of tile replacement because the grease has replaced the mortar.
I never know when I bid a job just how much tile they will lose, you tap on the tiles and they seam fine. usually the grout is the only thing holding the floor in place. When I bid on the work I make sure they sign off on complete replacement of anything I find. I also leave them the greasy tiles so they cant say I just padded the bill.
Old 03-12-2008, 09:27 PM   #18
fez-head's Avatar
I have never seen that particular grinder before - is it a Milwaukee? I looked at some Fein vacuum grinders online but could not justify the $400 price tag when I have my $80 Dewalt tuckpointing grinder just laying around.
fez-head is offline
Old 03-12-2008, 09:31 PM   #19
tile contractor
The grinder itself is a a Bosch. The attachment was separate. I'll get the name and post it tomorrow.
TSP.
Old 03-12-2008, 09:37 PM   #20
fez-head's Avatar
TSP.
Thank you Bill I really appreciate that.
fez-head is offline
Cleaning Grout Lines housepainter Flooring 12 02-10-2008 02:38 AM
Need help on grout Red Ceramic & Stone Tile 10 01-15-2008 08:42 PM
Tile grout color too light fsbr Flooring 18 11-29-2007 06:05 AM
Grout width query. Nick S. Ceramic & Stone Tile 18 10-12-2006 10:22 PM
best way to seal grout for glass mosaics. ApgarNJ Masonry 2 06-27-2006 06:18 AM
