Replacing Piece Of Laminate On Floating Floor
Old 11-18-2006, 10:24 AM   #1
Spencer's Avatar
Trade: General Construction
How would you go about replacing one of the interlocking pieces in the middle of a floating floor.
Just curious because we lay quite a bit and I wouldn't know where to begin if I had to.
Spencer is offline
Old 11-18-2006, 12:35 PM   #2
Teetorbilt's Avatar
Re: Replacing Piece Of Laminate On Floating Floor
Look here http://www.floorexpert.com/Armstrong...e?OpenDocument it's easier than me typing it all out.
Albert Einstein
Teetorbilt is offline
Old 11-25-2006, 09:52 PM   #3
J&J Home Imp.'s Avatar
Trade: Flooring and Trim
Good link. I have never had to do it but I am sure I will eventually.
J&J Home Imp. is offline
Old 10-24-2008, 11:42 AM   #4
mike190's Avatar
Trade: cabinetmaking
Hi. I've got the same question...do you have to tear up the entire floor to get to the bad peice, or can you safely "stair-step" and remove pieces to get to the bad area?
Thanks
mike190 is offline
Old 10-24-2008, 02:51 PM   #5
DavidC
DavidC's Avatar
You only remove the peice to be replaced. I assume the link provided by Teeterbilt has the how to. You basically cut it out, remove the underside of the groove edge and glue it in.
Good Luck
www.CookContractingLLC.com
DavidC is offline
Old 10-24-2008, 03:19 PM   #6
mike190's Avatar
Good Luck
Hi Dave
I can't see that working with a floating laminate floor that has tenons/grooves on both sides?
Mike
mike190 is offline
Old 10-24-2008, 03:55 PM   #7
Professional Instigator
rbsremodeling's Avatar
drill some holes in it take you sheet rock knife (the nice one with a new blade) and cut it out and snap/glue a new one it.
If you can stick a coat hanger in one of the holes you drill and tug gently a few times to try to loosen the bad board from the rest and give you some room to cut it out that only works some times
rbsremodeling is offline
Old 10-24-2008, 04:51 PM   #8
DavidC
DavidC's Avatar
Originally Posted by mike190 View Post
Hi Dave
Mike
Mike, I've only done it a training seminar (I'll claim that as a testament to our work:>) but can assure you that it will work. You leave one tounge intact on one end, remove the other tounge and the bottom of both grooves. It will drop right in but does need to be glued with a weight on it or it will lift right out again. I'm working from memory so suggest again Teetorbilt's link for complete instructions. Lay out some leftovers in your shop or garage and have go at it. You may be suprised.
Good Luck
DavidC is offline
Old 10-24-2008, 05:39 PM   #9
Certified Remodeler
silvertree's Avatar
Trade: Kitchen bath remodeler
I did it once after the guy working with me dropped a screwdriver and took out a dime size chunk. Scared me to try, but I drilled a hole in the piece, got out my Fein tool and carefully made some cuts. Left one tongue and used a lot of glue, cleaned up excess glue and put a weight on overnight.
Never got called back for any problems, and the HO was an accountant, he would have called back if it had not worked.
silvertree is offline
Old 12-03-2008, 02:23 PM   #10
GaryS's Avatar
Trade: Laminate & Real Wood Installations
The above works for real wood floors not laminates for laminates either cosmeticaly repair damage or lift floor back to damaged area and replace
GaryS is offline
Old 12-03-2008, 03:38 PM   #11
DavidC
DavidC's Avatar
My experience was at a training seminar, where we allegedly were to learn proper (manufacturer endorsed) installation and repair techniques. It worked at the seminar and is considered acceptable by the manufacturer.
Have you got any real life experience with it yourself?
Good Luck
DavidC is offline
Old 12-04-2008, 09:38 AM   #12
Knowledge Factory
Floordude's Avatar
Not true.
Board replacement works for all wood and laminate flooring. It all depends where in the room it is, if I'll remove planks to get back to the damaged, or if I cut out the single plank.
http://www.AustinFloorguy.com
Floordude is offline
Old 12-06-2008, 02:57 AM   #13
THE FINISHER
lawndart's Avatar
Trade: Finish Carpenter
Send a message via AIM to lawndart
Replacing a board of laminate is easier than replacing a strip of hardwood flooring, if you know what your doing.
lawndart is offline
Old 12-06-2008, 08:40 AM   #14
AtlanticWBConst's Avatar
Originally Posted by Floordude View Post
Not true.
I'll back up Floordude's statement, because we have done repairs on both laminates and hardwoods with the same method described as well....
- Build Well -
AtlanticWBConst is offline
floor not level for hardwood laminate sterling stone Flooring 14 02-18-2007 05:41 PM
Laminate Wood Flooring Over An Old Garage Floor mjm0073 Flooring 1 01-30-2007 10:42 PM
Laminate Floor Richard Flooring 15 12-22-2006 12:59 PM
floating floor MarcM8181 Flooring 3 11-04-2006 03:26 PM
Q: Armstrong Floating Laminate Floor gieriscm Flooring 6 02-13-2005 09:06 AM
