Trade: Commercial interior super
Removing Tile That Is Set Under Base Cabinets..
Hey all... Went to look at a tiling job that was in the kitchen. Anyway, there is currently tile there that is failing, in a few spots, nothing major. Just some cracking on a few. I believe due to poor craftsmanship. The homeowner wants new tile and so forth.
The current tile is under the cabinets. I've never removed tile that was under the cabinets, just to the toe-kick. What's the procedure for removing the tile? I would assume to just cut the tile where it meets the cabinet, but there is a bit of intrusion from the cabinet face, to the cabinet base. I'm not able to use my grinder with a 4' tile blade to cut it.. I've thought about just using an air-hammer with a chisel, but then with the face of the cabinets there, i would be coming in at about a 30 degree angle which would have me taking out the front of the cabinets base support. What to do? I also thought of just laying down laminate right over???? But Not to sure of that..
"Relentless in Reliability and Satisfaction!" Oh yeah, 1 other thing... Assuming doesn't make an a55 out of me and you, it makes an a55 out of YOU and YOU!!!
solar guy
Trade: solar contracting
Re: Removing Tile That Is Set Under Base Cabinets..
I use a rotary hammer set on hammer only and a wide chisel and break it off at the toekick. Once I add underlayment it covers right up with the tile.
Trade: flooring- tile/marble/stone/wood & laminate
I usually offer some options to resolve the damage that does occur from remove tile at the toe kick that still is set underneath the cabinet base.
One, if possible remove the toe kick prior to demo and rest after demo prior to your install of the tile. Second, you can put ceramic tile onto the toe kick. Third, re laminate or re board the toe kick. |
Remodeling GC
try the crane toe kick saw with diamond blade and tape off cabinet so no damage to cabinets works great.
Kevin Basement Finishing Highlands Ranch Colorado Littleton Colorado, Basement Remodeling Kitchen Remodeling Denver |
#5 | ||
Re: Removing Tile That Is Set Under Base Cabinets..Quote:
That looks like the exact tool I would need. I am going to call my local tool rental tomorrow. Thanks Kevjob!
Professional Instigator
tape up the toe kick up real nice. Chipping hammer out the old tile, if you take your time you will get really close with the hammer, put down shoe moulding where the new tile hits the cabinet.
Send Rory 2 dolla |
I like Green things
Multimaster, or tell them they should pull the cabinets and counters.
#8 | |
"da Whale don't hesitate"
Trade: Hard Surface Flooring
If you are laying laminate I don't see the need in pulling the tile though, unless there is a height issue. If it's on a slab I can't see where a 1/2" would make much of a difference. If its on wood and your pulling tile and backer that makes sense. edit: You can also tile directly over existing tile, provided it is sound, bonded well (golf ball test it!), and there is NO cracking of tile or grout. Just a thought.
Precision Flooring (772) 237-9900 Tile, Hardwood, Laminate, and Resilient Installation, Sales & Repair - "We do it right the FIRST time" Last edited by PrecisionFloors; 05-26-2009 at 06:54 PM. |
#9 | |
He mentioned air chisel to demo the floor. If its laminate tile I need to go stop him pronto |
bujaly, I think I know what you are saying, your worried about taking the support away from the bottom of the cabinets. What I have done in the past when doing something like this is just sorta remove the tile infront of one cabinet at a time reshimming as I go as nessesary. Make sure the cabinets are screwed together so one holds the next. Heck you could even have the HO empty the cabinets.
Dave |
| The Following User Says Thank You to dkillianjr For This Useful Post: | TileLady (06-02-2009) |
#11 | |
classic muscle
Trade: General Contractor Tile Contractor
Knowledge Factory
Harbor Freight Tools has a Crain toe kick saw knock off. It is about $40
Dont do it , I burned one of those out on one job of ripping up 3/4 ply
#14 | |
Knowledge Factory
Heck, it paid for itself, and you took it back and got a new one, right? Hehehehe. Believe it or not, I have had many Harbor Freight Tools last longer than I ever expected. I have been using one of their cheap table saws for the easy work, for 9 years now.
#15 | |
I like Green things
Take 4 hours to pull the counter and lowers in a modest sized kitchen? How much time and effort will go into messing around trying to get the tile from under the kicks? |
| The Following User Says Thank You to WarnerConstInc. For This Useful Post: | 21gun (08-24-2009) |
#16 | |
Trade: no
My thoughts exactly. Just pull the bases and be done with it. It'll ultimately save you a lot of frustration, and you'll get a better looking finished product than a "lop and butt." |
Actually it did make me four times what I paid for it on that job , but the 3/4 ply with the ceramic residue proved to be too much for it.
It went into the bin of unwanted and broken tools at the warehouse....Along with the bucket saw. |
#18 |
If I ever was on a job and told my customer- contractor-or store owner- that I needed to pull out cabinets to rip up and install a new floor I would be takin Barista lessons in no time
#19 | |
Remodeling GC
| Base Trim! Before or After Floor Tile? | Cole | Flooring | 37 | 08-29-2011 08:58 PM |
| Building cabinets | PA woodbutcher | Finish Carpentry | 46 | 03-27-2009 12:29 PM |
| Exterior Slate Tile Balconies - Need some advise | NAV | Ceramic & Stone Tile | 5 | 01-06-2009 06:36 PM |
| tile backer in a bath room and kitchen | mikeybobo | Drywall | 10 | 12-05-2008 04:31 PM |
| Removing asbestos floor tile: Space suits needed? | Ted W | General Discussion | 19 | 01-29-2007 02:38 PM |
