Removing Stuck Down Carpet Padding
Old 08-25-2008, 05:03 PM   #1
grace5's Avatar
Trade: Old Crusty Carpenter
How can I remove stuck down carpet padding from a hardwood floor?
(its not rubber,but foam)
Lots of scraping results in little removal,is there some chemical I could use as I have tried goof-off,oops ,snake oil , ect to no avail
grace5 is offline
Old 08-25-2008, 05:19 PM   #2
Mike Costello's Avatar
Trade: Flooring
Send a message via Yahoo to Mike Costello
Re: Removing Stuck Down Carpet Padding
Nothing is going to magically remove it. A scraper and some elbow grease is your best option
Mike Costello is offline
Old 08-26-2008, 05:31 PM   #3
Flooring Installer
rusty baker's Avatar
Trade: flooring
Sometimes a scraper will work better if you dull the blade a little. A sharp blade tends to dig in the wood, instead of scraping off the foam.
rusty baker is offline
Old 08-26-2008, 09:15 PM   #4
Tile Contractor
Bud Cline's Avatar
How much do you have to remove and what color is it?
Bud Cline is offline
Old 08-26-2008, 10:26 PM   #5
Knowledge Factory
Floordude's Avatar
A drum sander, and a real big guy to run it, maybe two guys.
http://www.AustinFloorguy.com
Floordude is offline
Old 08-28-2008, 11:06 AM   #6
TRICK
ClassicCarpets's Avatar
Trade: Flooring
There is a product called Detach made by Parabond that you should be able to use.
ClassicCarpets is offline
Old 08-28-2008, 03:39 PM   #7
Trade: Flooring
Ahh, better living , by chemicals.
Im buzzed already
Old 08-28-2008, 05:08 PM   #8
Tile Contractor
Bud Cline's Avatar
What's your new floorcovering going to be? I don't think I would be using Detach on wood. Hell you'll never get rid of that disgusting odor if it soaks into cracks and woodgrain.
Old 08-28-2008, 07:23 PM   #9
Knowledge Factory
Floordude's Avatar
Think what is going to detach, when it gets finish applied!!!!!
Never use chemicals, unless your able to flood the place with water, more then once.
Chemical residue is a bond breaker, that will haunt you, big time!
Old 12-05-2008, 08:39 PM   #10
BellairRP's Avatar
Trade: remodeling and painting
Lightbulb
What is the best way to remove vinyl adhesive on a hardwood floor?
I assume the same as the stuck carpet padding; scrape and sand.
BellairRP is offline
Old 12-05-2008, 08:40 PM   #11
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
Bostiks best has an adhesive remover safe for hardwood flooring. I have used it.
Very nice-
Floorwizard is offline
Old 12-05-2008, 09:06 PM   #12
BellairRP's Avatar
Florcraft, Thankyou for the info. If I have a problem getting my hands on some Bostiks.
Ill know who to ask.
Old 12-07-2008, 02:59 PM   #13
Flooring Guru
I found it at Lowes
Old 12-12-2008, 01:16 AM   #14
sparehair's Avatar
Trade: Painting, flooring
I had a small patch of mastic I didn't want to sand (potentially asbestos). The flooring company had a specialized stripper by the five gallon. He suggested I try laquer thinner. Worked great and evaporated fast. Sanded the next day and refinished no problems.
sparehair is offline
tips on painting baseboards with carpet floor and a tip for new painters Zeebo Painting & Finish Work 10 04-22-2011 06:42 PM
Carpet Laying Tips Bozzy Flooring 15 07-10-2009 02:57 PM
$199 Carpet Installation For Your Entire House. Celtic Flooring 68 06-28-2009 09:09 PM
New to carpet tile J&J Home Imp. Flooring 7 06-22-2007 07:05 PM
Carpet and hardwood J DoubleD FLoor Flooring 7 09-16-2006 02:03 PM
