Removing Sheet Vynl
Alright so im removing sheet vynl from 6
different floors in this rehab house, and they all pull right up, but the bottom sticks to the slab from the glue I immagine. I've been soaking it with lots of water and using my 6'' drywall knife to scrape it up, I was wondering if theres any tips you flooring guys know of that would speed up the process. Thanks for any advice. |
Sean
Re: Removing Sheet Vynl
A 4" scraper (not the cheap ones either) & elbow grease
Like the ones seen here http://www.tiletool.net/Floor_Scrapers.asp Not sure how one of those electric ones will work |
Flooring Installer
Trade: flooring
Dull the blade a little. If it's too sharp it will dig into the floor underneath.
I see these guys using a long handled scraper that you hook up to an air hose. Sorta like a really long air chisel, but with a scraper blade on the end. I have no idea what you call it, but it works like the cat's backside.
EDIT>... I just Googled "pneumatic floor scraper", only to find out the thing is called a pneumatic floor scraper.
"da Whale don't hesitate"
Trade: Hard Surface Flooring
Cut it into 4" strips first. Less surface area to fight with = easier removal. If its still a night mare, pull the wear layer off first and then soak the floor with warm water for about 20 minutes, should come up easy. I usually only have to use a stand up 4" razor scraper. If it is a huge amount, consider renting a take up machine for 4 hrs.
Precision Flooring (772) 237-9900 Tile, Hardwood, Laminate, and Resilient Installation, Sales & Repair - "We do it right the FIRST time" |
Alright sounds good I appreciate the advice!
#7 | |
Re: Removing Sheet VynlQuote:
If anything like wp removal I suspect it might, except the wp adhesive is not as heavy as some flooring adhesive. |
#8 | |
#9 | |
Handle It!
Is this who you meant???
#10 | |
I hadn't thought of what Precision mantioned. I guess that would entail very good rinsing. I have use dit once on a concrete floor, but it really did not impress me. |
Old school Ranger
Trade: flooring
Once the wear layer is removed soak the floor with odorless mineral spirits and let it soak for about 20 minutes and the scrap. This has always worked great for me. If the felt backing starts to dry before you get to it reapply the mineral spirits. The felt back must be wet to scrap it off.
| Easily removing Wallpaper !!!!!YUCK!!!!! | PaintedLady | Specialty Coatings | 13 | 04-19-2011 06:32 PM |
| Good sheet vinyl | neolitic | Flooring | 21 | 05-25-2009 07:26 PM |
| Wanna see a $1300 sheet of plywood? | Gus Dering | Finish Carpentry | 57 | 03-23-2009 07:44 PM |
| Radiant Barrier Fact Sheet | Ed the Roofer | Roofing | 0 | 02-09-2008 08:57 PM |
| Apparently $7 a sheet is Good??????????? | 1KingOfDrywall | Drywall | 39 | 04-10-2007 11:08 AM |
