Removing Linoleum Flooring
I purchased my first home (fixer upper) in January and have been doing quite a bit of work on it. I'm an avid DIY'er and eager to learn. Next week, my kitchen cabinets arrive so I'm about to start my kitchen remodel. I want to replace the linoleum floors with prefinished hardwood. Any advice on this matter is very much appreciated.
I spoke with a carpenter I was considering for the cabinets and he said to leave the linoleum as a moisture barrier. Then I spoke with another contractor and he said to absolutely remove it. He said if I ever got a leak somehow, the water would have no way of getting out from between the linoleum and the hardwood, which would mold, mildew, and eventually rot. I have a plywood subfloor When I ripped up the linoleum to tile the bathrooms, the adhesive didn't come up very well. That was ok b/c I spread thinset down, then put down 1/4" Hardibacker. Is there a slick way to clean off large sections? I'd like to avoid renting a drum sander. Any non-toxic chemicals? Thanks in advance. |
Flooring Guru
Trade: Sales Manager
Re: Removing Linoleum Flooring
Well, first, you need to find out how old the lino is.
Then I would need to know what kind of wood is going down...engineered? or solid? this will help in my answer.
------------------------ "in 20 years you will regret more what you did not do than what you did" |
#3 | |
The linoleum (per the previous owner) was less than 1 year old. I'm putting in solid 3/4" maple.
Flooring Guru
It's not about moisture, because lino or not, when you nail into it, it pretty much negates any moisture barrier anyway.
What it is about is resiliency. Vinyl is too resilient to nail solid wood into. It needs to be nailed directly to the Plywood without vinyl on it. Too much cusion could make the wood perform lousy....gaps..ect... Remove the vinyl or install new plywood on top of it.
#5 | |
Any tricks on removing the remaining adhesive after pulling up the linoleum?
If you remove the vinyl and it's over luaunn(1/4 inch plywood) it's easier to pull the luaunn as well. Often(after only a year) the vinyl is stuck pretty well, and will destroy the luaunn anyway. Acouple of good prybars and cut the vinyl at the subfloor seams.
Or if hieghts not an issue, go over it with a new layer of subfloor. Hope this helps Don |
Flooring Guru
I couldn't have said it any better.
| Removing a small section of laminate flooring | MKamis | Flooring | 3 | 07-30-2007 06:02 PM |
| Hardwood Flooring - First Go at It | DecksEtc | Flooring | 56 | 10-05-2006 01:41 PM |
| Removing Tile over hard wood flooring | CMSuper | Flooring | 10 | 04-28-2006 10:43 AM |
| Question about floating wood flooring | zoner11 | Flooring | 10 | 01-17-2006 05:04 PM |
| Re-claimed Vertical grain fir Flooring | Coop | Flooring | 5 | 11-13-2005 08:49 PM |
