Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 06-19-2008, 03:21 PM   #1
Trade: General Contracting
Removing Hardwood for Tile
I am tiling a bathroom with existing hardwood floors. I am installing a marble threshold at the door. Do they make a Threshold to cover the hardwood I have to cut. Where do you recommend cutting the hardwood ( middle of door, even whith edge of jamb????). What should I cut the floor with to make a fine cut inside the door way? Is there going to be a gap between the hardwood and the threshold? Thanks
headcrash0101 is offline   Reply With Quote
Old 06-19-2008, 03:30 PM   #2
davy crockett's Avatar
Just curious? Ever tile before? If you are a DIYer you might get better results at the DIY site cause what you're asking is basically" How to "and these guys are gonna clean your clock here. This site is for Pro's to help each other. Sorry mate
davy crockett is offline   Reply With Quote
Old 06-19-2008, 03:32 PM   #3
Trade: Registered (cough) Home Improvement Contractor
Hi, nice to meet you too I'm Dan, from south Jersey. Can you make your own wooden threshold?
Alwaysconfusd11 is offline   Reply With Quote
Old 06-19-2008, 03:47 PM   #4
genecarp's Avatar
diy site, good luck
genecarp is offline   Reply With Quote
Old 06-24-2008, 11:08 PM   #5
Catch what you'll eat.
MattCoops's Avatar
Trade: Tile & Paint
Are you removing the hardwood floors?
What's the substrate?
Better yet, what's the deflection of the floor?
Why are you needing a threshold? What's the covering of the adjacent room?
Matt; tile contractor in Charlotte, NC
704-605-0907
Tweeting @MattCupan | read my articles
MattCoops is offline   Reply With Quote
Old 06-25-2008, 02:56 PM   #6
Trade: Flooring(hardwood/tile)
cut the wood with a skilsaw... use a tmold that matches the wood... I generally transit the floor to not show 2 different floors from either side of the door if its closed...
how thick is the current wood? tile? using 1/4" 1/2" cement board or something else? DIY forum...
ridewags is offline   Reply With Quote
installing hardwood over hardwood? yohan61 Flooring 21 02-18-2009 07:16 PM
Hardwood Flooring - First Go at It DecksEtc Flooring 56 10-05-2006 12:41 PM
Hardwood over hardwood? dkillianjr Flooring 9 09-21-2006 08:07 AM
Removing hardwood from under cabinets GriffDecker Flooring 60 12-20-2005 11:46 PM
Questionss on Hardwood underlayment and expansion newtofloor Flooring 8 11-24-2005 08:18 PM
