Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 01-06-2007, 09:13 PM   #1
Trade: n.c. general contractor
Removal of glued down carpet over oak floor
I AM IN THE MIDDLE OF RENOVATING AN OLD RENT HOUSE TO SELL AND UPON REMOVAL OF THE CARPETS I FOUND CARPET UNDER THE EXISTING CARPET IT IS ALMOST A COMMERCIAL LOOKING CARPET WITH A BLACK RUBBER BACKING THAT IS GLUED DOWN TO THE ORIGINAL 3/4" T&G SOLID OAK FLOORING( THAT I WOULD LIKE TO REFINISH) WHEN I TRIED TO TEAR IT UP THE RUBBER BACKING STAYS PUT ( GOOD GLUE LUCKY ME ) ANY SUGGESTIONS OTHER THE OBVIOUS SCRAPER AND ELBOW GREASE?
SPEEDSQUARE is offline   Reply With Quote
Old 01-06-2007, 10:50 PM   #2
Teetorbilt's Avatar
Quit screaming! BTW, welcome to work. You want a floor scraper, the weighted kind. Hone the blade so that you can nearly shave with it and go easy. This is almost impossible to describe especially if you are not used to working with wood. You need to always work with the grain and ........
Maybe you need a pro.
Albert Einstein
Teetorbilt is offline   Reply With Quote
Old 01-07-2007, 11:16 AM   #3
747
747's Avatar
Nope. Thats should be your game plan. I did it before but it was glued to cement. Wood is going to make it twice as hard.
747 is offline   Reply With Quote
Old 01-07-2007, 11:22 AM   #4
Trade: resi elec newbie
Something like this?
390 Inertial Scraper This new floor strippers helps you plow through the toughest vinyl tile and ceramic tile removal jobs with less effort. Its metal handle is weighted to produce inertia, and has rounded edges to prevent core palms. Its beefed-up carrier has 3 tightening screws. Comes with one 5" blade. Made by Crain Tools.
http : // www dot tiletool dot net/390_cmyk_small.jpg
Mark Twenhafel is offline   Reply With Quote
Old 01-07-2007, 11:24 AM   #5
Here's the actual pic:
Old 01-07-2007, 06:42 PM   #6
Suck it up, or shut up
get some good knee pads I bought a pair of "pro-knee"and they made a big differance. 40 hours on a 18 x 12 room. scraping, heat gun, and a lot of loud rock and roll. Then drum sanded starting with 20 grit, and moving all the way to 120 grit
now that I'm finished, I'm glad I didnt take any short cut's.
rservices is offline   Reply With Quote
Old 01-07-2007, 06:54 PM   #7
Insert title
dougchips's Avatar
Trade: Doors-Windows-Decks
You can try mineral spirits in a small area. I did a floor a few years ago and it worked ok. I used it to remove 12x12 self stick foam backed carpet tiles.
dougchips is offline   Reply With Quote
Carpet Removal on Concrete trichar7@maine. Flooring 6 04-16-2008 02:21 PM
Glued down carpet puller Marizzaldi MFG Tools & Equipment 4 03-13-2007 11:17 PM
Glue down carpet removal dayspring Flooring 29 11-15-2006 05:59 PM
Carpet removal from walls Guardi Pro Painting & Finish Work 6 08-26-2006 10:40 AM
tips on painting baseboards with carpet floor and a tip for new painters Zeebo Painting & Finish Work 7 10-23-2005 01:20 PM
