Refinishing Problem With Hardwood Never Seen Before
Old 05-26-2008, 04:13 PM   #1
wayne3434's Avatar
Trade: carpenter/remodeling
im refinishing an old hardwood floor ive completed all sanding and noticed one spot had this black tarlike substance seeping up through tiny hole so i wiped it up and it stained like it was tar or oil so i sanded it down. today i went back and a lot of that **** seeped up i have never seen this in my life has anyone any idea what it could be and what i could do to stop it?
wayne3434 is offline
Old 05-26-2008, 05:00 PM   #2
mdshunk's Avatar
Re: Refinishing Problem With Hardwood Never Seen Before
Artesian oil well?
mdshunk is offline
Old 05-26-2008, 05:03 PM   #3
Steve
OCRS's Avatar
Do you have access to the underside of the floor?
OCRS is offline
Old 05-26-2008, 05:06 PM   #4
mdshunk's Avatar
Pitch Pocket: 1. A defect in wood; consists of an opening in the grain that contains pitch or resin. Also called a resin pocket.
mdshunk is offline
Old 05-26-2008, 05:22 PM   #5
Teetorbilt's Avatar
New to me. Some of the old guys used to use roofing felt under hardwood. Usually it just dries up.
You may have problems outside of the flooring.
Albert Einstein
Teetorbilt is offline
Old 05-26-2008, 05:29 PM   #6
Professional Instigator
rbsremodeling's Avatar
I still use the roofing felt if the moisture below the floor is high. It seems to work better than the cheap a55 rosin paper
rbsremodeling is offline
Old 05-26-2008, 05:58 PM   #7
Knowledge Factory
Floordude's Avatar
It may very well be cutback tar adhesive, residue.
The sanding heated it up and it is wicking up, is a possibility.
http://www.AustinFloorguy.com
Floordude is offline
Old 05-29-2008, 06:55 PM   #8
wayne3434's Avatar
thanks guys its only seaping up from one piece of flooring i wiped it up and sanded stain off but is still coming up what do u think i could do? what if i sand it and then seal it before it starts seaping up again?or i could replace the one piece of wood.
Old 05-29-2008, 08:31 PM   #9
Carpetologist
csheafer's Avatar
Trade: Carpet, Vinyl & VCT Installation since 1977
Are you talking about sealing just the one area or the whole floor?
If you are talking the whole floor, I think that would be a mistake.
I think that replacing that one plank would be the best option.
csheafer is offline
Old 05-29-2008, 08:38 PM   #10
Steve
OCRS's Avatar
If you have access, have you looked at the under side of the floor? Trying to seal the floor will probably only result in the finish lifting.
OCRS is offline
Old 05-29-2008, 10:17 PM   #11
Mike Costello's Avatar
Trade: Flooring
Send a message via Yahoo to Mike Costello
Black gold. Texas Tea
Mike Costello is offline
Hardwood floor refinishing dkillianjr Flooring 18 05-10-2011 04:16 PM
Moisture Problem Milhaus Commercial Construction 6 12-26-2007 02:47 PM
Well problem paintr56 Plumbing 10 02-09-2007 09:20 AM
Hardwood over hardwood? dkillianjr Flooring 9 09-21-2006 09:07 AM
I need help on refinishing hardwood flooring estimate smitty58 Flooring 10 02-01-2006 07:28 AM
