Refinishing Beveled Edge Flooring
Old 11-09-2010, 01:16 PM   #1
Hair Splitter
TNTSERVICES's Avatar
Trade: General
Rewards Points: 2,638
Need a little info on beveled edging and how to refinish. I have refinished several floors, but never with beveled edges.
1) What is the best way to get in the bevel between the boards remove the old finish and prep for the new finish?
2) How much should I add to the estimate for the trouble?
Thank you!
Rob
TNTSERVICES is online now
Old 11-09-2010, 05:36 PM   #2
astor's Avatar
Trade: FI
Rewards Points: 704
Re: Refinishing Beveled Edge Flooring
Many ways to do,for one, you need couple of these(<$1.00):sharpen and clean out, then go over with sand paper
or
For the cost: depends width,deepness etc.test how fast you can get it done;try on small area and time it.
astor is offline
Old 11-09-2010, 06:50 PM   #3
wannabe
WNYcarpenter's Avatar
Trade: carpentry
Rewards Points: 1,000
This is interesting, I've wondered this also.......are you buffing and re-coating or are you going down to the raw wood?
sounds like a buff and re-coat... the can opener is a good tip, thanks.
If you're sanding to raw wood......... I'm thinking you would have to take out the bevel. Stop marks would look even worse, and scraping each groove would be a major PITA!
WNYcarpenter is offline
Old 11-09-2010, 07:57 PM   #4
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 3,098
Beveled edge one's are usually pre-finished flooring right?
I thought you had to chemically strip those?
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
Old 11-09-2010, 08:00 PM   #5
Hair Splitter
Trade: General
Some renter drilled a bunch of 3/4" and 1" holes that need to be filled, so I need to take down to bare. The bevel is deep at least 1/8" so taking that much material off is not an option. I had thought about routing the grove, but that could get out of control if not careful. I would have to nail guides to keep everything straight. Not sure how that would work. Luckily we are going darker with the finish. I am almost tempted to just sand the surface, degloss the grove and poly. The groves are much darker as is. Any other thoughts?
Old 11-09-2010, 08:28 PM   #6
wannabe
Trade: carpentry
the stock answer would be to contact the manufacturer and get some more info.
IMPO.......I would cut out the damaged boards and replace with a color match then buff and re-coat. Keep the same color.......sanding, chemical strippers etc...could get real ugly........
Old 11-09-2010, 08:30 PM   #7
Hair Splitter
Trade: General
The house was built in the 50's. I plan on patching in new boards where the holes were drilled, but I still have the issue of trying to sand in the grooves.
Old 11-09-2010, 09:01 PM   #8
wannabe
Trade: carpentry
Oh....sorry..... I presumed this floor was new-ish prefinished flooring.....
Old 11-09-2010, 09:13 PM   #9
Wood Craftsman
PrestigeR&D's Avatar
Rewards Points: 4,642
Lightbulb
Have you thought of Stripeez.... that should clean it out pretty much... I use that a lot when I have an architectual piece that is rather intricate with carvings or details....I let it do the work for me..I think you will have a better outcome... JMPO
B.
PrestigeR&D is offline
Old 11-09-2010, 11:21 PM   #10
Hair Splitter
Trade: General
B.
On 1600 sq feet of flooring....I think I'll pass, but thanks for the option.
Old 11-09-2010, 11:57 PM   #11
RhodesHardwood's Avatar
Trade: Hardwood Floors
Rewards Points: 590
Most times on prefinished floors like this their is a very tough finish. So you need to start sanding with a pretty heavy grit. Most of the time, it will have sanded out by your last pass.
RhodesHardwood is offline
Old 11-10-2010, 12:06 AM   #12
Hair Splitter
Trade: General
I don't believe they put in pre-finished floors in the 50's, did they?
Old 11-10-2010, 12:11 AM   #13
Rewards Points: 590
No they didn't. Not that I'm aware of anyway. I am also not aware of site finished flooring with a bevel. Either way I would still sand it out, unless the bevel is really deep. In that case a carbide scraper would easily clean them up.
Old 11-10-2010, 12:18 AM   #14
Hair Splitter
Trade: General
That's what I was afraid of. Like I said before I was kinda hoping for a new fancy tool that you set it and plugged away...but I guess I can always get what I want or wish for.
My grandpa always said wish in one hand and sh*t in the other and see which is filled first. I have several scrapers, time to eats me spinachk and flexk me muskles.
Old 11-10-2010, 08:32 PM   #15
astor's Avatar
Trade: FI
Rewards Points: 704
Regular scrapers may not be the best,I attach the can openers to a wood handle with couple screws and use it.Trust me that is best way.They stay in the groove.Keep it sharp and one pass will do it.
BTW no matter what you do, the grooves will be darker than flooring.
astor is offline
Beveled edge tutorial Gus Dering Finish Carpentry 17 09-15-2010 08:26 AM
Edge Flooring JoeBergess Flooring 4 02-28-2007 11:28 PM
Re-claimed Vertical grain fir Flooring Coop Flooring 5 11-13-2005 08:49 PM
