Recommend Me A Moisture Meter
Old 04-17-2009, 12:52 AM   #1
jhark123
Guest
jhark123's Avatar
Posts: n/a
Hello all,
I have decided to get a moisture meter for trim and possibly doing a hardwood floor or two. what's the industry standard unit?
Old 04-17-2009, 09:57 AM   #2
woodfloorpro
Guest
woodfloorpro's Avatar
Posts: n/a
Re: Recommend Me A Moisture Meter
I use a Wagner 220 for fast readings and use an Mini Ligno DX to cross check my Wagner especially if the subfloor is 3/4" because since the Wagner reads 1" you will get false readings. I also use the hammer probe attachment for the Ligno when doing inspections to read moisture at different levels in subfloor. You should also get a Thermohygrometer to monitor ambient humidity. Hope that helps
Old 04-17-2009, 08:09 PM   #3
Floordude
Guest
Floordude's Avatar
Posts: n/a
Originally Posted by jhark123 View Post
Hello all,
Tramex: Professional wood moisture meter. What all other meters are compared to.
Delmhorst: J-2000. Nice accurate meter.
Both are pin type, and the only true method of getting accurate readings. Non-invasive meters are a waste of money.
Moisture Moisture Moisture... fixitpete Flooring 22 12-30-2008 04:13 AM
Crawl Space Ventilation Ed the Roofer Roofing 2 11-27-2008 11:15 AM
redguard on densGuard trap moisture? wopachop Ceramic & Stone Tile 14 11-20-2008 02:09 PM
Tenwolde's 5 Myths Of Moisture Ed the Roofer Roofing 3 02-10-2008 03:37 PM
Moisture meter Richard Painting & Finish Work 10 11-11-2006 08:10 AM
