Real T&G Floor Over Slab
Old 01-16-2005, 03:42 PM   #1
trekr's Avatar
What do you guys do to install real oak flooring over a slab? Sleepers? Also, what type of sealer/vapor barrier do yo use if any? Any thoughts are, as always, appreciated.
trekr is offline
Old 01-16-2005, 09:02 PM   #2
pondman's Avatar
Re: Real T&G Floor Over Slab
Must be floated on top of one by's. Always disclose what happens if a toilet or sink or any water malfunction in household happens. Take it up and throw it away.
pondman is offline
Old 01-17-2005, 07:36 AM   #3
Custom Builder
Glasshousebltr's Avatar
I would scratch the true hardwood idea right off the bat, too many negitive attributes. Install floating, save money and future problems.
Future problems? Pond hit it right on the head, water, moisture, cold conduction, additional height, TAPCON failure, I think thats just the tip of the ice burg.
But then again who am I?......How did I get here?.......It feels like it's close to feeding time.
Bob
Glasshousebltr is offline
Old 01-17-2005, 11:49 AM   #4
trekr's Avatar
Thanks guys. I'm not real gung ho on the idea myself. However, they (Mrs.) think the laminates feel "cheap" to walk on. And it seems like the consensus on here is there really isn't any way to get rid of the hollow feel of Pergo type products. Any other ideas or do I pitch the pros and cons and get to work?
trekr is offline
Old 01-17-2005, 02:02 PM   #5
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
WWW.KAHRS.COM
great engineered wood floor that is thick. is won't sound like 3/4 that is nailed down, but it will sound better than lam.
Floorwizard is offline
Old 01-17-2005, 11:57 PM   #6
trekr's Avatar
Thanks for the info, I'll check them out.
trekr is offline
Old 01-19-2005, 10:05 PM   #7
GenConJ's Avatar
I did a job for a commercial site where the owner went all out to get the floor he wanted. The floor was a 2500 sq/ft slab. He had us install the following...
1) layer of black industrial adhesive applied w/ a 1/4" square notch trowel (my guys called it cold tar) It was alot like Gorilla Snot for windshields.
2) layer of 6mil poly (plan ahead how to roll it out)
3) 1/2" plywood fastened w/ powder actuated nailer
4) roofing felt
5) Brazilian Cherry hardwood
I have never really talked about that job. But it was a nice floor w/ a great feel.
GenConJ is offline
Old 01-20-2005, 07:28 AM   #8
Custom Builder
4) roofing felt
Was that true hardwood or floating lam. If floating lam, why the sub-layment?
Also what kind of product was the gorilla snot?
Bob
Old 01-20-2005, 03:41 PM   #9
GenConJ's Avatar
3/4" T&G Nail down unfinished
GenConJ is offline
Help Installing Hardwood over old/new Concrete Slab Hages Flooring 7 06-04-2008 01:02 PM
built up slab question stampcrete Concrete & Paving 9 03-27-2008 05:24 PM
Demo a foundation under a radiant heat slab without disturbing the slab...? wackman Remodeling 18 04-02-2007 12:38 AM
Fiber reinforced slab cost in central NJ gschotland Masonry 0 11-18-2006 02:27 PM
Basement slab question n74tg Masonry 5 05-26-2006 04:38 PM
