Rasen Paper Or Felt
Old 02-24-2005, 06:27 PM   #1
wehavnfunyet's Avatar
Rasen Paper Or Felt
i was in a debat over what to use under wood floor rosin paper verses felt
what do you pros use ?
wehavnfunyet is offline
Old 02-24-2005, 06:33 PM   #2
GenConJ's Avatar
Re: Rasen Paper Or Felt
Felt
GenConJ is offline
Old 02-24-2005, 09:49 PM   #3
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
Felt
Floorwizard is offline
Old 02-24-2005, 11:10 PM   #4
Don Benham's Avatar
Send a message via AIM to Don Benham
I hate to go against the grain on this one....
...so I won't.
Felt.
Don
Benham Flooring
__________________________________________
Look, I know the voices in my head aren't real, it's just that lately they've had some really good points.
Don Benham is offline
Old 02-25-2005, 01:41 PM   #5
ccoffer's Avatar
Felt is the safest bet. It can retard vapor transmission due to a temporary catastrophe in a basement or crawlspace. Other than that, there is no difference in felt and rosin paper under your wood.
That crap about reducing sqeeks and stuff is a bunch of hooey.
ccoffer is offline
Old 03-10-2005, 11:34 AM   #6
Marco's Avatar
Trade: Hardwood Flooring
Location: The Oak Floors of Marco Los Gatos, CA 408-353-4882
Rosin(kraft) paper usually. Easier to work with, boards slide easier when nailing. I prefer the results of kraft tho, I think it gives a slightly 'softer', quieter floor imo.
Years ago at Bruce school in Memphis, we were told off the record that Bruce didn't believe it was all that important to use anything because you were poking thousands of holes through the paper and moisture would wick right up the cleat/staple. Cheap easy insurance tho.
Marco is offline
Rosin paper or roofing felt? Mike Finley Flooring 35 01-06-2009 03:06 PM
Type of Paper Under Hardwood CharlieDaw Flooring 2 04-12-2007 10:43 PM
roofing felt bwashington Roofing 2 08-10-2006 10:52 AM
commercial wall paper removal rservices Wallpaper 1 06-28-2006 09:58 PM
Felt paper used as insulation??? Age General Discussion 9 06-10-2006 04:25 PM
