Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 02-27-2009, 11:53 AM   #1
Trade: Flooring Installer
Question about decision made by carpet manufacturer rep
I had a call back on a carpet install job that I did due to seams looking bad. When the job was originally installed, the seams looked good and the customer signed off on the paperwork acknowledging that. As the months went by, the seams started to get worse, very noticeable. When I went out to look, I notived that every seam had become very noticeable and there seemed to be a slight shading issue. Now, I am not perfect but my seams are generally pretty good so I could not understand how every inch of every seam now looked horrible. I could see parts of certain seams looking bad but not all of them. Long story short, they sent out a rep who ended up stating that it was an installer issue due to gaps and peaking. When I looked over the job, I will admit, I did notice some slight peaking and there was a few small gaps due to very crooked rows from the row running when I seamed it up. This was a very short but thick cut pile carpet. My questions are, how could every seam get worse over time (roughly a year), what is the deal with the shading & how can the rep say that it is due to gaps when 99% of the seam is nice & tight. I had 1 certified installer mention something about "crocking", does this sound familiar to anyone? Sorry for the long post but I am wondering what my options are as I have never had a job turn out like this and never had to replace someones carpet due to install errors.
Thanks
Chad
Proimagefloors is offline   Reply With Quote
Old 02-27-2009, 03:47 PM   #2
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
What type of latex was used on the seams?
Floorwizard is offline   Reply With Quote
Old 02-27-2009, 05:42 PM   #3
Trade: Flooring
Send a message via Yahoo to Mike Costello
Lol, I'm not touching the crocking.
The mistake most guys make when doing cut pile is that sealer is not used. That will fail an inspection sure as I sit here. You have still cut the edge of the backing and it needs to be sealed
There could be a giant praying mantis eating the seam in front of the inspector, but if the seam was not sealed it will fail an inspection.
Not for nothin because I row cut most of my cut pile seams too, but if I put it together and noticed gaps I would redo it using a strait edge.
I also do a bunch of stuff to eliminate peaking, I stretch the seam before melting it ( tape doesn't stretch), keep my 6 inch iron on 2 as I seam ( yes i use a 6 inch on almost everything), use a seaming board under the seam, usually luan. I also bought one of those seam weights with the Teflon perforated bottom that seams to work way better than my tray
Mike Costello is offline   Reply With Quote
Old 02-27-2009, 05:44 PM   #4
Trade: Flooring
Psst Fastlock isnt latex old schooler
Old 02-27-2009, 06:35 PM   #5
Flooring Guru
Maybe I am bored and easily amused, but that was really funny.
That my friend is called good advice...
Old 02-27-2009, 10:18 PM   #6
Trade: Flooring
Thanks, been doing more carpet these days thanks to the economy
Old 02-28-2009, 11:56 AM   #7
Sarcastic Prick
Trade: Paint and Floor Covering Retailer
If, after all that has been said, you feel that you are still not at fault and it is an issue with the carpet, you need to have an independent inspector come in and look at it. You never take the carpet reps word for it. Their primary interest is protecting the carpet company. Shaw will arrange for an independent inspector at no cost to you most of the time. Mohawk on the other hand will try to avoid inspection at all cost, in my experience at least, so it may vary from one company to another.
http://www.morrispaint.com
gideond is offline   Reply With Quote
Old 02-28-2009, 12:08 PM   #8
Knowledge Factory
Floordude's Avatar
How did you cut the seams??
Row gauge can show a gully, or compression, if not correct width as the carpet is made with.
http://www.AustinFloorguy.com
Floordude is offline   Reply With Quote
Question for GC re: rough/final cleans britanie General Discussion 6 06-07-2009 06:42 PM
Metal roof question Burby Roofing 11 01-22-2009 01:16 PM
Question from lawyer trying to help contractor scp Business 43 01-20-2009 10:02 AM
Cost Plus Question randybelk@comca Business 16 09-11-2008 09:09 PM
Sewer Infrastructure Question ABLE1 Excavation & Site Work 20 05-28-2008 10:05 AM
