Quarter Round (QR) Transition From Hardwood To Metal Door Threshold?
Old 12-15-2017, 09:37 AM   #1
svankirk's Avatar
Trade: Handyman & Light Remodeling
Rewards Points: 98
Hi folks,
Flooring newbie here. I just finished my first engineered hardwood installation. Prior to that I'd only done a little tile.
The owner of the flooring store where I bought the hardwood sold me a quarter round (QR) to cover the expansion gap between the flooring & the metal edge of the exterior door threshold. (I did show him a picture, BTW.)
Obviously I can't attach the QR to the flooring itself, as the expansion/contraction of the floor will tear it up and/or leave a gap between the QR & the metal door threshold. If anything, the QR will have to be attached to the metal threshold.
So here are my questions:
1. Was I sold the wrong trim piece? In researching this, a baby threshold seems like it's maybe a better option than QR. But installing one now will mean cutting back the flooring to make room for it. Not a big deal, but a little time-consuming.
2. If QR is indeed a good option, how do you securely attach it to the metal threshold? I'm assuming I shouldn't drill holes into the threshold (i.e. pilot holes for finish nails)? Would construction adhesive or some other type of glue be best?
FWIW, I'd really like to do this right - I want to end up with a quality installation.
Thanks, for the help!
Steve
Simply Renewed Spaces
svankirk is offline
Old 12-15-2017, 09:48 AM   #2
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 1,060
Re: Quarter Round (QR) Transition From Hardwood To Metal Door Threshold?
Expansion/contraction of engineered flooring is minimal. If you've got a 21 guage pinner, pin the QR to the floor & use a bead of silicone where the QR meets the threshold. Silicone will stretch as much as the floor contracts. If it expands, the pins will bend allowing for floor movement that direction.
pinwheel is online now
The Following User Says Thank You to pinwheel For This Useful Post:
hdavis (12-15-2017)
Old 12-15-2017, 10:03 AM   #3
hdavis's Avatar
Rewards Points: 3,417
No step height greater than 1/4" is allowed. Any rise more than that has to be no more than 1" rise in 2" run. I don't think quarter round ever meets code in this application.
hdavis is online now
Old 12-15-2017, 10:06 AM   #4
pinwheel's Avatar
You've obviously not seen some of the jobs I've worked on
Old 12-15-2017, 10:13 AM   #5
hdavis's Avatar
LOL, I know what you mean.
Even custom cutting thresholds, It's impossible to meet code with wonky floors because you're allowed 1/2" for the interior threshold thickness. I'll get the step height and the slope to code and the thickness is whatever works.
Old 12-15-2017, 10:39 AM   #6
svankirk's Avatar
Rewards Points: 98
Thanks for the reply!
Is this true even if the fllooring material isn't man-made?
It's advertised as "engineered hardwood". Near as I can tell the flooring is made of actual wood, it's only "engineered" in that man has put it together in cross-grain layers like plywood. So it's basically 3-ply plywood with the top layer being a very nice finished oak. In other words, the materials themselves aren't man-made like a laminate. So unless I'm wrong, it'll expand/contract like a plywood. This is still much less than than solid wood, but probably more than a man-made material.
Does that change anything regarding your suggested approach, or do you think it would still work?
Oh, BTW: the room is only 11' wide, in case it matters for understanding total expansion & contraction. The flooring was allowed to acclimate for 5-7 days or so before installing.
Thanks,
Steve
svankirk is offline
Old 12-15-2017, 10:47 AM   #7
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 3,600
Thanks,
Steve
That's what engineered wood is. Instead of solid hardwood, it's a veneer on plywood. It doesn't move much. If it's floating click together style, then it may move a decent amount. Nailed down, not so much.
There are many ways to skin this cat. Glue to the threshold as you say, or nail it through the QR into the sub floor, missing the hardwood.
Golden view is online now
The Following 2 Users Say Thank You to Golden view For This Useful Post:
hdavis (12-15-2017), pinwheel (12-15-2017)
Old 12-15-2017, 10:48 AM   #8
hdavis's Avatar
Thanks,
Steve
He'll tell you it doesn't change anything.
Old 12-15-2017, 10:49 AM   #9
hdavis's Avatar
Cross post....
Old 12-15-2017, 11:00 AM   #10
svankirk's Avatar
Rewards Points: 98
This is a floating installation, FWIW.
Also, I saw hdavis' reply "cross post..." Not sure what that means. Was there another post I should have read first? Did I post this question in the wrong area? My apologies, if so.
Thanks,
Steve
svankirk is offline
Old 12-15-2017, 11:24 AM   #11
avenge's Avatar
Rewards Points: 2,556
Just nail it to the subfloor and be done.
avenge is offline
Old 12-15-2017, 12:46 PM   #12
hdavis's Avatar
Thanks,
Steve
I wrote an answer in case Pinwheel couldn't get back to you right away, but he was answering you at the same time I wrote mine. That's the cross post, he posted his before I posted mine that was just in case.
Old 12-15-2017, 10:58 PM   #13
svankirk's Avatar
Rewards Points: 98
Transition has been installed.
Brought the quarter round back to the store & got an end cap. It worked great & also happened to match the flooring better. In my opinion it also looked a little more professional than the QR. Had to trim it a bit on the table saw (i.e. rip cut), but other than than, no hiccups. Laid down some construction adhesive & nailed it to the subfloor.
BTW, in this particular case the QR would only have overlapped the flooring by about 1/8". I didn't feel comfortable with that, which was one of the main reasons I brought it back. The other is that it was vinyl & didn't do the hardwood justice.
Thanks for all your help, folks - I really appreciate it!
Steve
svankirk is offline
The Following 2 Users Say Thank You to svankirk For This Useful Post:
hdavis (12-16-2017), pinwheel (12-16-2017)
Old 12-15-2017, 11:40 PM   #14
avenge's Avatar
If someone would give me vinyl to match hardwood I'd probably slap them, no thanks I'll just make my own.
avenge is offline
The Following 3 Users Say Thank You to avenge For This Useful Post:
allaboutfun (12-16-2017), hdavis (12-16-2017), pinwheel (12-16-2017)
Old 12-15-2017, 11:54 PM   #15
svankirk's Avatar
Rewards Points: 98
Thanks for confirming that. I look back now & wonder why he suggested such a mediocre transition for such nice flooring. Live & learn, I guess...
Steve
svankirk is offline
Hardwood Transition Floormasta78 Flooring 29 07-05-2012 02:11 PM
Metal roof question Burby Roofing 11 01-22-2009 01:16 PM
Question with quarter round haskl33 Carpentry 14 05-31-2008 07:49 AM
How to Cut hardwood for round stair nosing!! winnabowboy Flooring 3 09-17-2007 08:21 PM
quarter round Ian Flooring 17 11-20-2005 11:57 PM
