Q: Armstrong Floating Laminate Floor
Old 02-12-2005, 04:15 PM   #1
gieriscm's Avatar
Send a message via AIM to gieriscm
http://www.armstrong.com/reslaminate...p?itemId=74275
I'd like to have the above floor installed in my townhouse in the dining/living area, front hallway, and kitchen. This is a "glueless" floating floor, the best quality that Armstrong makes. The floor would be installed over a concrete slab, and even though the water table is low in my area (Virginia) I'm going to insist that the concrete be sealed.
A contractor I spoke with said that I don't want a laminate floor since if one piece gets damaged beyond repair, the whole floor would have to be replaced. I could see that happening with a glue-down floor, but couldn't a piece of glueless laminate be replaced by carefully taking it apart, replacing a piece, and putting it back together? Or, do people replace floors because the manufacturer may no longer be making that particular style/color any more, so finding a piece to match is difficult, if not impossible, and very costly?
Any thoughts appreciated. Thanks!
gieriscm is offline
Old 02-12-2005, 04:52 PM   #2
Teetorbilt's Avatar
Re: Q: Armstrong Floating Laminate Floor
High end Armstrong is a good choice. The contractor was wrong, changing out a panel is not that difficult and you don't have to disassemble the floor. Save a few of the big drops and buy an extra box, store in a cool, dry place just in case. A different lot# can make a difference.
Teetorbilt is offline
Old 02-12-2005, 07:05 PM   #3
Don Benham's Avatar
Send a message via AIM to Don Benham
Ditto.
Benham Flooring
__________________________________________
Look, I know the voices in my head aren't real, it's just that lately they've had some really good points.
Don Benham is offline
Old 02-13-2005, 01:11 AM   #4
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
Ditto here too.
By the way, find someone with a different opinion.
Floorwizard is offline
Old 02-13-2005, 01:12 AM   #5
ccoffer's Avatar
The underlayment is key. You needn't depend on a sealer when you can simply buy a quality underlayment. I prefer a product called Sound Solution made by Healthier Choice in Dalton Ga. They have an iron clad guarantee.
Using 6 mil polyethylene is pretty cheap insurance toward avoiding moisture probs associated with laminates. Despite sales pitches to the contrary, none of them are very dimensionally stable.
CHU
ccoffer is offline
Old 02-13-2005, 01:31 AM   #6
Custom Builder
Glasshousebltr's Avatar
Get you a hamma drill and some tapcons and UNfloat the baby.
Bob
Bob
Glasshousebltr is offline
Old 02-13-2005, 09:06 AM   #7
Teetorbilt's Avatar
Sealing the concrete is just cheap insurance. I noticed on my first job that just walking on the poly sheet can cause micro punctures due to a small stone in a boot tread or one trapped between the membrane and the floor. I spent a lot of time taping holes on that job. I'm pretty convinced that with 2 coats of sealer the vapor barrior is redundant but it goes down anyway for warantee reasons. I just think about what it would cost to tear it all out and start over.
Replacing Piece of Laminate on Floating Floor Spencer Flooring 13 12-06-2008 08:40 AM
floor not level for hardwood laminate sterling stone Flooring 14 02-18-2007 05:41 PM
Laminate Wood Flooring Over An Old Garage Floor mjm0073 Flooring 1 01-30-2007 10:42 PM
Laminate Floor Richard Flooring 15 12-22-2006 12:59 PM
floating floor MarcM8181 Flooring 3 11-04-2006 03:26 PM
