Profit is not dirty.
Trade: Residential Drywall and Taping
Putting Tile On Plywood.
hey guys..
as you may see i am a drywaller, and do not have much expertise on flooring.. but i need some info for putting tiles over plywood. i suggested using hardi board then tile on that...any suggestions. J
Profit is NOT a dirty word....Cheap is.... |
Remodeling GC
Re: Putting Tile On Plywood.
look into ditra www.schluter.com easy to work with and not much height.
Kevin Basement Finishing Highlands Ranch Colorado Littleton Colorado, Basement Remodeling Kitchen Remodeling Denver |
Ditra, easy to work with and is waterproof. Most of the tile distributors around here carry it, I have even seen it at HD.
#4 | |
Sean
Re: Putting Tile On Plywood.Quote:
2) Seams (Thin Set & Tape) 3) Thin Set - Tile Heavy, pain to cut, labor intensive, not expensive Schluter - awesome product, easy to cut, less labor intensive, expensive, good to use if there are expansion contraction issues, or excessive water may be an issue Either will work out fine & last a long time |
Trade: Renovations
I hope you've done some homework prior to this. Are the joists stiff enough for tile? Is the plywood thick enough for tile?
Doesn't matter what you use over the plywood if the joists or the ply flexes the floor will fail.
#6 | |
Tiling & Bath Contractor
Trade: Tiling & Bathroom Remodeling
thanks guys
Yes the joist are strong enough....2x8 12 o/c and its 5/8 ply t&G. Its in a older log home, and it seems to shift slightly, and the owner wants it done properly as do i.... My thoughts were to use tape joints,thinset, hardi, and then tile...that is what i did on my own place...cost is not the issue..its what would be proper and the right way ....i was just curious if there was another product out there that would also work... Thank again to all J
#8 | |
Knowledge Factory
The time and labor saved should make up for the cost of Ditra.
| information on fixing a bad tile job | bford | General Discussion | 4 | 09-30-2008 07:44 AM |
| Is there a "REAL" problem with putting tile on a sub floor? | Project53 | Flooring | 20 | 06-16-2008 05:03 PM |
| Learning to install Floor and Wall Tile!! | TurnkeyConst | Flooring | 25 | 01-17-2008 08:01 PM |
| Prepping a Plywood Subfloor for Tile After Demolition | bluethumbnail | Flooring | 8 | 01-01-2008 09:47 AM |
