Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 04-27-2008, 09:21 AM   #1
Trade: General, roofing and insulation contractor
Pros & cons of pre-finished hardwood flooring?
WE've got 750 sf. of wood flooring to do on a remodel project. I have an employee who has considerable experience installing wood floors. He says the pre-finished is actually superior to the standard install/sand/finish method. The HO is being tugged at in different directions by other "experts", (sales professionals)....
What say you?
Thanks!
tnt specialty is offline   Reply With Quote
Old 04-27-2008, 11:24 AM   #2
Sarcastic Prick
Trade: Paint and Floor Covering Retailer
Unfinished can get you a smoother floor since you can sand the whole thing smooth once it's installed. It also seals better since you are putting the poly over the entire surface at once, allowing it to soak in between the boards as well as on top of them.
Prefinished has a much tougher wear layer on it. Most good companies use 5-9 coats of acrylic urethane with Aluminum Oxide in it to toughen the finish. This cannot be done in the field to unfinished floor at this point. It's also less labor intensive and faster to install. You nail it down and you are done. No sanding or clear coating afterwards. You do not get as good of a seal though since no poly is applied to soak between the boards. You also have a microbevel on the edges so the floor with lot be as smooth overall. You have to have that bevel so irregularities are not noticed, since you can't sand the whole thing smooth.
gideond is offline   Reply With Quote
Old 04-27-2008, 11:34 AM   #3
Thanks gideond.
My client is extrtemely anal....He's worried about the beveled edges collecting "dirt". The tougher finish would be the only benifit to this particular client.
Appears there's more cons than pros......for the pre-finished.
Old 04-27-2008, 12:58 PM   #4
Sarcastic Prick
Yep, I sell a lot of hardwood in our store and the biggest complaint I run into with the customer is about dirt in the microbevel. I've seen plenty of these floors that have been down for years and I don't notice any dirt collected there. The bevel isn't huge. Maybe if you never sweep or damp mop the floor it could be an issue.
There are also products like Khars to consider. Engineered but extremely good. These floors have a real hardwood top layer with the aluminum oxide wearlayer but since they are a locking product they allow for a smooth floor with no bevels. Of course you customer will probably have opinions about an engineered product being sub par to a solid wood product.
Old 04-27-2008, 01:17 PM   #5
Cpt. Chaos
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
There are prefinished products out there without a bevel, just an fyi.
Precision Flooring
Hampton, VA (757) 256-0848
Tile, Hardwood, Laminate, and Resilients
PrecisionFloors is offline   Reply With Quote
Old 04-27-2008, 03:24 PM   #6
Trade: Flooring
Send a message via Yahoo to Mike Costello
You can tell him he isnt that anal if he has enough dirt in his house to collect in the grooves
Mike Costello is offline   Reply With Quote
Old 04-27-2008, 10:16 PM   #7
hammerwhipped's Avatar
What say you?
Thanks!
It sometimes depends on the use of the space and how wide the planks are.
If the planks are 5"or wider it's best to use the engineered flooring because its less likelly to cup. But if this is for a kitchen go with the unfinished because it's better against spills/stains. In my opinion I would go with an unfinished product because it's eaiser to install and can be sanded and refinished many more times.
hammerwhipped is offline   Reply With Quote
need some pros and cons 98mustangguy Flooring 11 04-04-2008 09:14 PM
Hardwood Flooring Install, Little Help. spartiatis Flooring 4 02-17-2008 12:18 AM
Eos Solar Collectors Pros & Cons? RopeaGoat HVAC 0 01-22-2008 09:56 PM
Hardwood Flooring - First Go at It DecksEtc Flooring 56 10-05-2006 12:41 PM
Hardwood Flooring For Large Projects StonewoodSP Marketing & Sales 1 12-08-2005 09:38 PM
