Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 01-07-2009, 12:53 PM   #1
Trade: Home Improvement Contractor
Prefinished hardwood no bevel
Hey, Could one of you guys recommend a place to get a prefinished hardwood floor without a bevel? Looking for the material only.
Thanks
Glenn
gzec is offline   Reply With Quote
Old 01-07-2009, 01:39 PM   #2
Trade: wood flooring
try linden floor supply.
they used to have a line from medallion that made a solid prefinish with no bevel.
jamestrd is offline   Reply With Quote
Old 01-07-2009, 06:17 PM   #3
Cpt. Chaos
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Pro Source
Precision Flooring
Hampton, VA (757) 256-0848
Tile, Hardwood, Laminate, and Resilients
PrecisionFloors is online now   Reply With Quote
Old 01-08-2009, 12:19 AM   #4
Trade: carpenter
I always thought the bevel was there do hide differences between boards. The bevel makes the transition gradual from board to board. I have seen floors with a fairly large bevel (Bruce). The material I am putting down in my house has a bevel but is fairly small. doesn't feel to bad on the feet. I'm sure it will still trap dirt like any beveled product though. Maybe higher quality products have a better milling process so that they don't need the bevel? good luck.
Monrovi is offline   Reply With Quote
Old 01-08-2009, 06:04 AM   #5
Trade: Flooring
Send a message via Yahoo to Mike Costello
Also try installing a pre finished floor with n bevel. The un beveled top edges wil be cracking and splitting left and right from the nailer
Mike Costello is offline   Reply With Quote
Old 01-09-2009, 01:04 AM   #6
Designers
astor's Avatar
Trade: Wood Cork and Leather Flooring
Are you sure..
Micro bevelled prefinished floors has polyurethane finish even on the bevels,unless it is an undermaintained(dirty) restaurant like that, the bevels will not trap any dirt, even chewing gum does not stick to it..I got to explain this quite often to consumers.If you spill ketchup and even do not clean and let it dry,it will not stick to polyurethane finished surface.It will come out eventually by the foot traffic
If anyone is familiar with the production of solid flooring, will see that to get a precise T&G is almost impossible due that production speed, wood properties etc.Italian and German machines that makes hardwood flooring in North American market uses sensors to adjust cutting heads every 15-20 seconds in order to get same distance tongue-to surface dimensions,even that is not good enough to make non bevelled solid floor without overwood.Then you run into problems like protecting the sharp edges in boxes, transportation,on site while installing etc.I have seen some had tried but than the subfloor needs to be like glass in order to install without any imperfections.
Non-bevelled wood fooring is available in engineered version from many reputable companies such as BR111,Berti etc.
Featuring Click Leather Floors
http://www.designershardwood.com
astor is offline   Reply With Quote
Old 01-12-2009, 06:47 AM   #7
Trade: Self employed - hard surface installer
Installing square edged (S4S) factory finished hardwood is the majority of my solid wood jobs. Bruce Fulton Strip is one of a few products. And as already noted, the substrate needs to be made extremely flat. It pays good.
Jerry T is offline   Reply With Quote
Hardwood over Asbestos Tile 4yanx Flooring 10 11-08-2008 08:39 PM
Sanding prefinished hardwood nwtile guy Flooring 8 04-27-2008 09:11 PM
prefinished hardwood / durability stevengould46 Flooring 1 08-02-2007 11:01 PM
Hardwood over hardwood? dkillianjr Flooring 9 09-21-2006 08:07 AM
nailing prefinished hardwood floor Handyman Jay Flooring 7 03-15-2006 12:09 PM
