Prefinished Hardwood Floors Is It Ok To Spline In The Middle Of The Room.
Old 07-20-2009, 11:05 PM   #1
andeeznuts's Avatar
I was wondering if it is ok to start in the middle of a room and spline back the other direction after one side is done. Im doing it this way because it is an insurance job and i need to fit around fire place trim. Planning on putting wood glue in the tongue and grove for strength thank you.
andeeznuts is offline
Old 07-20-2009, 11:46 PM   #2
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Re: Prefinished Hardwood Floors Is It Ok To Spline In The Middle Of The Room.
Absolutely, do it all the time. Actually every time in large open areas as it cuts your expansion in half.
Precision Flooring
(772) 237-9900
PrecisionFloors is offline
Old 07-21-2009, 10:01 AM   #3
Knowledge Factory
Floordude's Avatar
Yes, use a slip tongue/spline.
There is a DIY sister site to get more info.
http://www.AustinFloorguy.com
Floordude is offline
Old 07-22-2009, 11:42 AM   #4
the big 12 inch's Avatar
Trade: hardwood floor contractor 28 yrs.
Iv'e always wondered why the floor mills don't make a board with a tongue on both sides to make changing directions easier...Id keep a few bundles in the shop...who's with me?..
the big 12 inch is offline
Old 07-22-2009, 11:56 AM   #5
Originally Posted by the big 12 inch View Post
Iv'e always wondered why the floor mills don't make board with a tongue on both sides to make changing directions easier...Id keep a few bundles in the shop...who's with me?..
Yep, wondered the same thing myself. Heck, they could charge twice as much for 'em and it would be worth it to me. I can make my own splines and do most of the time, but it takes time....
Precision Flooring
(772) 237-9900
Old 07-24-2009, 10:17 AM   #6
Knowledge Factory
Floordude's Avatar
Because of mass production, those boards would be mass produced too. The problem with that, it would be a totally different production line, the stock would have to be wider to have enough meat to mill a tongue on both sides and the prefinished may look totally different as it often does with different production runs.
It would stick out like Dolly Pardon, standing in a runway model line up.
Old 07-24-2009, 01:32 PM   #7
I would think that distributors could work with a local shop in their area to mill these boards...I'm sure if they were available hardwood guys would buy em....I do agree that it wouldn't work with prefinished..
Old 07-27-2009, 11:46 PM   #8
THE FINISHER
lawndart's Avatar
Trade: Finish Carpenter
Send a message via AIM to lawndart
We use slip tounge on our hardwood flooring projects all the time. It helps with the expansion of the boards.
Best New York Flooring Installers For Hardwood Floors
lawndart is offline
Old 07-28-2009, 01:34 AM   #9
KemoSabe
loneframer's Avatar
I had a flooring installer tell me that you can't start a floor off of an interior wall, that it has to start off of an exterior. The problem is, the longest exterior wall was 15' long and it was run toward a 42' long interior wall, around a circular stairwell too. Needless to say, by the time they made it to the wall, it ran from a full board at one end, to 1 3/4 at the other. Also had a couple buckles in it from working around the stairwell. After arguing with the installer and the flooring supplier who hired them, they basically installed the floor for free. I wanted it ripped out, but the HO was willing to take the discount.
After it was all over, the installation manager said that the reason it was done that way was because they don't like to slip-spline engineered flooring. Even though they had to do it around the stairway anyhow.
loneframer is offline
Installing solid hardwood floors over particleboard dsmoser Flooring 35 07-13-2011 12:01 PM
Price to install real hardwood flooring and remove carpet Handyman4u Flooring 15 02-21-2009 09:36 PM
here's a painting price list...... Jer44 General Discussion 9 02-17-2009 08:30 AM
nailing prefinished hardwood floor Handyman Jay Flooring 7 03-15-2006 12:09 PM
hardwood floors question 747 Flooring 10 02-21-2005 09:49 PM
