Pre-finished Flooring
Old 03-01-2007, 04:03 PM   #1
C.C.R.'s Avatar
Trade: Remodeling contractor
Does $4.00/sqft sound about right to install 3 1/4" pre-finished red oak floor? I haven't bid a floor in quite awhile and don't want to lose it, it's about 1,000 sqft. It will be about 5.00 sqft. for material (includes markup). So $10.00 sqft. total. It' in an upscale neighbor hood. Half is new construction, half is going to be taking the place of existing carpets. Now I know the usual responses:
Varies from area to area.
What I need to make may not be the same as what you need to make. Etc.
I just need to know if it sounds like a fair price
$10.00/sqft. I supply material, I remove existing carpets. Install new floor, etc.
Complete Custom Remodeling
"When Quality is Top Priority"
www.completecustomremodeling.com
C.C.R. is offline
Old 03-01-2007, 09:47 PM   #2
It's all about the Avatar
woodmagman's Avatar
Trade: I have no face!
Re: Pre-finished Flooring
If you don't install all the time typically 1 installer slightly over weight and a coffee drinking helper can place about 260 sq.ft. of 2 1/4" flooring per day. Now if your young and your back is still strong you can do more so you can afford to buy doughnuts for your helper. It all depends on the area and the preperation.
woodmagman is offline
Old 03-02-2007, 11:19 PM   #3
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
10 bucks sounds reasonable....
for my area...
Floorwizard is offline
Old 03-05-2007, 08:00 AM   #4
THE FINISHER
lawndart's Avatar
Trade: Finish Carpenter
Send a message via AIM to lawndart
$10 bucks is reasonable in my area (NYC) also. Good luck.
lawndart is offline
Hardwood Flooring - First Go at It DecksEtc Flooring 56 10-05-2006 01:41 PM
Flooring in Log home C.C.R. Flooring 7 09-05-2006 09:58 PM
Question about floating wood flooring zoner11 Flooring 10 01-17-2006 05:04 PM
Re-claimed Vertical grain fir Flooring Coop Flooring 5 11-13-2005 08:49 PM
Laminate Flooring Gina Flooring 9 04-28-2004 12:06 AM
