Trade: vyni layer
Possible Moistre Prob
i have just been asked to go out and check out an vinyl installation where the previous layer laid over the top of parquetry.
it has been down for about a year, and recently in the last couple of weeks or months <im not sure which> the parquetry floor has began to buckle and pop off the floor. with my limited knowlege of timbre flooring products and not actully seeing the floor im suspecting possiblly a pipe has split inside the slab or some other form of moister. is there any other possibilities? |
Knowledge Factory
Re: Possible Moistre Prob
No, someone place a material with a high perm rating, over the wood, trapping all the moisture. If this is over concrete, it was just a matter of time. If it is over pier & beam, you have trapped the crawl space moisture.
You cannot place a moisture barrier over wood making a wood sandwich with moisture barrier bread.
| The Following User Says Thank You to Floordude For This Useful Post: | ian@prosource (05-15-2009) |
Zackly right.
Just had such an issue in a candy store at a mall. The installer put karndean over parquet wood tile - over a slab -and it buckled like you wouldn't believe. Got big bucks to rip up the jellybean Karndean, scrape the parquet off it and re install after putting a moisture retarder down. One of those cases where a hack actually helped me make money |
Casap CEO
Trade: Contractor Membership Service
Re: Possible Moistre Prob Good answer! Not to mention the vinyl installer used latex adhesive. They should have just pulled up the parquet or refinished it. Ron T |
| Hardwood Flooring Prob, HELP! | Boogga | Flooring | 8 | 07-29-2007 03:53 PM |
| mdshunk, try this: RPJ2 Gas Furnace similar ignitor prob | tpope | HVAC | 12 | 04-09-2007 01:25 AM |
| prob with dimming lights | greenley | Electrical | 2 | 01-06-2006 10:56 AM |
