Possible Asbestos Tile
Old 09-28-2006, 07:55 AM   #1
Suck it up, or shut up
rservices's Avatar
I have an old home 110 yr +/-
I'm not exactly sure but the vinyl floor in the dinning room mite have Asbestos, I know I should have it tested but I not going to, it wouldnt change the fact that it has to go.
theres a wonderfull hardwood floor under it.
I plan on wearing a dust mask, and protective clothing,
Heres the question.
It apperars to be layed on tar-paper seams to thick for it to be glue, I've removed a small section, most comes up in small sections.
for the stuff that dosent come up easy, or sticks to the floor. what can I put on it to loosen it. I dont want to gouge up the floor, or make sanding more work than it needs to be
thanks
rservices is offline
Old 09-28-2006, 07:39 PM   #2
dkillianjr's Avatar
Re: Possible Asbestos Tile
Are they individual tiles or is it a sheet? I've heard that most of the 9"x9" tiles are asbestos.
dkillianjr is offline
Old 09-28-2006, 07:54 PM   #3
rservices's Avatar
Thisis a single sheet. no Idea how old, exect that the pattern is old and ugly, the floor below is maple I think.
Old 09-28-2006, 07:55 PM   #4
mdshunk's Avatar
Originally Posted by rservices View Post
...the vinyl floor in the dinning room mite have Asbestos, I know I should have it tested but I not going to...I plan on wearing a dust mask, and protective clothing,
Are you frikkin nuts?? Mesthelioma is nothing to screw around with. I so sad to hear this from a contractor.
mdshunk is offline
Old 09-28-2006, 07:55 PM   #5
Teetorbilt's Avatar
There is a good article on just this thing in the new TOH mag. You can pick up a copy cheap or try their site. As I remember, there is not a great amount of risk with the tiles. I'd still be careful and different states have different laws as to disposal.
Albert Einstein
Teetorbilt is offline
Old 10-05-2006, 11:02 PM   #6
Super's Avatar
Trade: flooring
If you insist on taking up the tiles use a heat gun and 8" putty-knife.
This will end up causing some vapors. You should get a CHARCOAL mask and wear some sort of eye protection because you eyes absorb alot of whats in the air.
Super is offline
Old 10-10-2006, 10:13 PM   #7
Shanklesbuilder's Avatar
I actually just read about this last week. Some of asbestos tiles were 9x9 but many were not. I found out that they made 12x12 asbestos tiles till 1980. The fibers are the really dangerous b/c they are so small and they get in your lungs. Your lungs try to filter them out and this causes scaring in the lungs making it harder and harder to breeth. The scarring also many times leads to cancer. So yea as long as you dont get the fibers in the air you will be ok. The asbestos is not cancerous but what it does in your lungs can lead to cancer. Be safe and check local laws.
Shanklesbuilder is offline
Old 10-10-2006, 10:21 PM   #8
My custom title
Brushslingers's Avatar
Your ok. The black gunk that holds it down can be scraped and sanded, but the sheet flooring isn't abestos.
Benn
Originally Posted by Brian
Brushslingers is offline
Learning to install Floor and Wall Tile!! TurnkeyConst Flooring 25 01-17-2008 08:01 PM
Removing asbestos floor tile: Space suits needed? Ted W General Discussion 19 01-29-2007 02:38 PM
Asbestos Tile dama Flooring 2 07-04-2006 08:31 PM
Got some design ideas for tile wainscoting? Mike Finley Ceramic & Stone Tile 2 05-09-2006 10:05 AM
