Originally Posted by woodfloorpro
Putting plywood over particle board is not recommended. Just think of what the next guy is going to have to do if you're customer does end up with water damage issues. I would present the situation to the customer and explain that you need more time but if you must you need to pass through the particle board into the subfloor at least 3/4 of an inch with nails or staples and NWFA recommends 3/4" plywood. Mike
As a remodeler, I generally think of the next guy as I'm usually him. It's not a matter of her time I'm worried about, it's mine. Just had another 3 weeks of work thrown at me and will be balls to the walls until June. Don't think this is the time to be turning work down
The only water that the floor should be susceptible to would be mop water. I've been using rosin paper o the rest of the floors, but no reason that I couldn't use #30 felt instead. 3/4" would also be my choice for plywood..I was leaning towards plug and tough sanded, T&G. Glues in PTSTG are also rated for water contact, glued at the seams it should be pretty much impenetrable.
Any more advice would be appreciated, as always.
