Perimeter Caulk
Old 12-09-2008, 10:45 AM   #1
boman47k's Avatar
Rewards Points: 2,006
Perimeter Caulk
Any of you guys ever use any kind of perimeter caulk when doing floating laminate flooring? I noticed the floor guy at a house I recently did work at had some. I assume hewas going to use it to fill in the gaps around the perimeter of the rooms he installed a floating floor in. I have been to ask this for a while now.
I wouldn't think this would be necessary if the floor was done right, not only along the walls, but at the doorways around the jams also.
boman47k is offline
Old 12-09-2008, 11:04 AM   #2
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
Rewards Points: 2,000
Re: Perimeter Caulk
it's cheap insurance.
should be done in kitchens and bath's but why not everywhere?
Floorwizard is offline
Old 12-09-2008, 11:58 AM   #3
boman47k's Avatar
Re: Perimeter Caulk
Even on 1/2 to maybe 3/4 gaps around the doorjams and along the walls where maybe shoemoulding might not cover it? Seems to me even if you got a "matchihng" color, there would still be a sheen difference. Or was that sarcasm? He had a jam saw, and I do not understand why the areas around the doorjams were gapped like they were. Or were you being sarcastic?
boman47k is offline
Old 12-09-2008, 01:21 PM   #4
jamestrd's Avatar
Trade: wood flooring
Rewards Points: 1,280
Re: Perimeter Caulk
only place i ever used caulk in this type of installation was along bathroom saddles
jamestrd is offline
Old 12-09-2008, 01:21 PM   #5
Flooring Guru
Re: Perimeter Caulk
There should be no gaps around door jambs. The jambs should be undercut with a jamb saw and slid under.
Only hope is to redo it, or fill in with color fill. But it may take a bunch of tubes. It will still be VERY visible.
Old 12-09-2008, 01:58 PM   #6
The Finisher
lawndart's Avatar
Rewards Points: 668
Re: Perimeter Caulk
I've only caulked the perimeter in Kitchens (Around the cabinets).. I have been asked to, and refused to install wood, and laminate in bathrooms in the past. I'd rather walk away from it, then be called back because of moisture related issues in the future. IMO only ceramic, or Vinyl should be installed in a bathroom..
lawndart is offline
Old 12-09-2008, 02:27 PM   #7
Mike Costello's Avatar
Trade: Flooring
Rewards Points: 250
Re: Perimeter Caulk
Economy is too sucky to walk away from anything here in New England.
Just last week I put some engineered cherry in a bath. I tried to talk them out of it but the lady of the house was insistant . She saw it in a magazine and thats what she wanted. End of story.
So I glued it with Bosticks Best, glued the joints with Titebond and nailed it with my Powernails L cleats. Then I caulked around all edges and the toilet flange with some Phenoseal marine caulk.
Wont be my fault when it fails
Mike Costello is offline
Old 12-09-2008, 02:41 PM   #8
Flooring Guru
Re: Perimeter Caulk
That just doesn't make too much sense at all.
I have not seen a moisture issue come back to the installer unless they did not follow manufacturer instructions...so why worry about it?
Tile and Vinyl only in a Kitchen/Bath?
I can see recommendations maybe but not ONLY!
I am happy to hear you are able to walk away from jobs. Some people here are not that lucky.
That's good news for you.
I just disagree that only 2 floors should be put in any area.
Tile is cold, hard and is bad for the elderly because of their bones and fumbly fingers at times.
Vinyl is crap with no value at all.
Tile is durable and waterproof and Vinyl is cheap.
But by no means is it stupid to consider any other options.
Old 12-09-2008, 02:42 PM   #9
Flooring Guru
Re: Perimeter Caulk
Exactly
Old 12-09-2008, 02:51 PM   #10
The Finisher
lawndart's Avatar
Rewards Points: 668
Re: Perimeter Caulk
I'm sure I could've expanded on other options of flooring. However, Hardwood Flooring, and Laminate Flooring do not belong in a bathroom. You can glue the perimeter, and use the best adhesives on the market, it will not stop the floor from buckling in the future.
I've seen a couple dozen cases where hardwood, and Laminate flooring have failed in a bathroom. Show me an example of a reputable laminate or wood flooring manufacturer that warranties their product in a bathroom, and I might consider doing them in the future.
lawndart is offline
Old 12-09-2008, 02:55 PM   #11
The Finisher
lawndart's Avatar
Rewards Points: 668
Re: Perimeter Caulk
Actually Mike, it will be. If they take you to court, the judge will side with them, because, you as a the professional should know better. Will the manufacturer of said engineered flooring back the warranty if the floor fails?
lawndart is offline
Old 12-09-2008, 03:12 PM   #12
Flooring Guru
Re: Perimeter Caulk
Your on the East coast!
What about all the wood that has been in Bathrooms for years!?
New York
Boston
New Hampshire
FLORIDA!
I have replaced ALL flooring because of flooding. Even tile because the flooding affected other things and required replacement.
No need to not recommend flooring because of floods.
Armstrong, Wilsonart, Quickstep...ect...ect..
not for floods though.
No, there is not one manufacturer of ANY product that warranties because of flooding.
No it will not be. Unless the instructions required some other form of install.
There is not a Judge on earth that will blame an installer for flooding.
Look....I know what you are saying. I just disagree about ONLY.
I can agree that is would be better for long standing moisture to go with sheet Vinyl or Tile.
But I do not agree that an installer can be blamed for moisture issues.
Old 12-09-2008, 03:28 PM   #13
The Finisher
lawndart's Avatar
Rewards Points: 668
Re: Perimeter Caulk
With that logic, I guess its safe to throw away my moisture meter, and while I'm at it, forget acclimating the products, I always hated delivering the flooring 2 weeks early anyway.
BTW, I'm not talking about "flooding"... There is "long standing moisture" and high humidity levels in a bathroom, which is harmful to wood and laminate products.... You can choose to install in these conditions knowing the floor will fail in the future, but I will not just for the sake of getting a job, because times are slow.
lawndart is offline
Old 12-09-2008, 03:32 PM   #14
boman47k's Avatar
Re: Perimeter Caulk
My thoughts exactly.
The thing I can't understand is he had a jamsaw. No idea why he didn't undercut all the jams so he could make nice square cuts and slide underneath.
Not really surprised after he explained to me how he fix a spongy place (dip) in the floor by nailing the laminate. I think that kind of kills the floating floor aspect.
boman47k is offline
Old 12-09-2008, 03:36 PM   #15
Insert title
dougchips's Avatar
Trade: Doors-Windows-Decks
Rewards Points: 2,022
Re: Perimeter Caulk
For what it's worth, I've never seen a solid wood floor in MA, ME or NH. I've seen wide pine plank floors in VT and VA. The wide planks ones move so much that I think the water just drains under them into the basement or into the sub-flooring.
In reference to laminate flooring, I have yet to see a job that I liked in kitchens or bathrooms (after it's been installed for a while). Since I'm seeing it after the installation and I am not there to inspect it I'm not sure if it is installer error, crappy product or just failure due to normal kitchen and bathroom moisture.
To get the best replacement windows, or sun rooms contact the replacement windows experts at FHI Vinyl Window Company.
dougchips is offline
Old 12-09-2008, 03:52 PM   #16
Flooring Guru
Re: Perimeter Caulk
ok ok I see how technical you are...allow me to restate
Installers will not be liable for moisture issues if they stick to manufacturer recommendations and standard install practices.
That means that lam and wood is still a viable choice.
High humidity in a normal bath will not kill a floor, and longstanding moisture can be dealt with by the consumer.
All I am trying to say, is that it can work and work fine. Hundreds of thousands of people can't be wrong
Old 12-09-2008, 04:14 PM   #17
Trade: Flooring
Rewards Points: 250
Re: Perimeter Caulk
There is a little thing called due dilligence.
Where I took many steps to safegaurd the floor and strongly recommended against it I like my chances
Old 12-09-2008, 04:16 PM   #18
Trade: Flooring
Rewards Points: 250
Re: Perimeter Caulk
You serious? May be a bit of a stretch but I can say I see it at leastonce a week here in NH
Old 12-09-2008, 04:20 PM   #19
Flooring Guru
Re: Perimeter Caulk
Once a week in New Hampshire alone?!
OK maybe millions then.
I saw some houses in New Hampshire this year.
What an incredibly beautiful place to live.
I was in awe.....
Old 12-09-2008, 04:51 PM   #20
Trade: Flooring
Rewards Points: 250
Re: Perimeter Caulk
for the last ten years builders have been putting sand and finish hardwood in kitchens and half baths here pretty regularly.
Personally I dont really like it but I am certainly not going to put myself out of that market by refusing to do it.
As long as it is acclimated and installed properly I really cant see the liability issue for an installer that is doing it for a retailer.
Im sure Alaska is a beautiful place to live as well, I will make it out there some day
Caulk at tubline... ...or grout? Bazooka Joe Tiling 20 12-26-2008 01:39 PM
Storing caulk tubes on a trailer... SCBBUILDERS Tools & Equipment 15 12-08-2008 08:11 AM
Virgin Mary Appears in Skwerb of Caulk dokuhaku Off Topic (Non Trade) 7 11-18-2008 01:21 PM
Caulk quality Ralph6 Windows, Siding and Doors 5 09-04-2008 05:33 PM
Ceder siding to caulk or not to caulk??? Dave Mac Painting & Finish Work 10 05-26-2006 08:33 PM
