Pergo Patch In Middle Of Large Floor, Treat It Like A Hardwood Patch?
Old 11-10-2011, 11:21 PM   #1
Big Hammer B's Avatar
Trade: finish carpenter
Pergo patch in middle of large floor, treat it like a hardwood patch?
Big Hammer B is offline
Old 11-10-2011, 11:41 PM   #2
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
Re: Pergo Patch In Middle Of Large Floor, Treat It Like A Hardwood Patch?
Is there a question here somewhere, or do you plan on letting us all in on the conversation? Nice first post btw.
Precision Floors
(772) 237-9900
PrecisionFloors is offline
Old 11-10-2011, 11:52 PM   #3
Yeah thanks, its a question. I really did not want to take up all one side of floor just to get to a damaged plank. I could rip bottom edge off and set grooves in glue. Just not sure on this one.
Old 11-11-2011, 03:30 AM   #4
Orlando Car
Floormasta78's Avatar
Trade: certified floor covering installer.
Rewards Points: 1,154
The, only pergo that I have repaired was the original pergo that required glue on tongue and groove,, I'm talking about 1990's stuff ,,, after, that any click system laminate , even if glued back it would be hard for that, type of flooring to hold without one edge missing..
unless its the glue and strap type of installation laminate I would take it apart to the closest wall.
http://www.facebook.com/#!/certifiedfloorcovering
Certified Floor Covering
Serving All California
( 510 ) 760 - 6810
Floormasta78 is offline
Old 11-11-2011, 06:11 AM   #5
doncando's Avatar
Trade: carpentry and painting
Rewards Points: 25
Pergo is a floating floor system. It expands/contracts with changes in humididty. You can not replace a piece in the middle. You have to remove to the nearest wall and re-install.
doncando is offline
Old 11-11-2011, 09:53 AM   #6
dsconstructs's Avatar
Trade: Remodel Contractor
Rewards Points: 768
Best way.....from the nearest wall and pull it all up until you get to the damaged area.
Another way, if there's enough room between the edges and walls is something like this http://www.tools4flooring.com/crain-...ise-p-337.html
Cut out the bad planks and the rest of that horizontal row(s), separate the sections enough to lay new planks in and pull the sections back together. It does actually work, I've done it in a hallway so the sections weren't very wide. I wouldn't even try it in a big area but supposedly it works there also.
dsconstructs is online now
Old 11-11-2011, 10:42 AM   #7
Paul
WRONG. Stick to what you know - this ain't it. I have been to more Pergo training seminars than I care to remember. A plank replacement can be done in less than 20 minutes.
You are correct OP in that you can rip the bottom of the groove off to allow the plank to drop in place. I use simple Tite-Bond for a joint adhesive. I have a neat little way of making clamps out of scrap wood, drywall screws, and hot glue that keeps the replacement plank and it's adjacent planks edges on plane until the adhesive sets. It is not required in every situation, depends on the floor.
Precision Floors
(772) 237-9900
The Following 3 Users Say Thank You to PrecisionFloors For This Useful Post:
Floormasta78 (11-11-2011), slowsol (11-11-2011), Splinter hands (11-11-2011)
Old 11-11-2011, 11:55 AM   #8
Macsurfer83's Avatar
Trade: Flooring and Tile
I agree 100%!!!
Macsurfer83 is offline
Old 11-11-2011, 04:31 PM   #9
doncando's Avatar
Rewards Points: 25
OK. Thanks for the information. All I have to do now is know what I don't know and I won't make that mistake again.
doncando is offline
Old 11-11-2011, 08:04 PM   #10
Orlando Car
the professional way to do a plank replacement .. pergo, armstrong . unilin, any of these brands or any brand there is only one way to do a repleacement on hardwood or laminate .. THIS IS IT .!
Pergo patch in middle of large floor, treat it like a hardwood patch?-838.jpg   Pergo patch in middle of large floor, treat it like a hardwood patch?-837.jpg   Pergo patch in middle of large floor, treat it like a hardwood patch?-840.jpg   Pergo patch in middle of large floor, treat it like a hardwood patch?-841.jpg
( 510 ) 760 - 6810
The Following User Says Thank You to Floormasta78 For This Useful Post:
bluebird5 (11-12-2011)
Old 11-11-2011, 08:14 PM   #11
astor's Avatar
Trade: FI
Rewards Points: 704
Not worth to invest just one piece but, THERE IS AN APP FOR THAT!
Bulldog video:
+ YouTube Video
astor is offline
Old 11-11-2011, 08:31 PM   #12
Orlando Car
that is a cool tool sam.. i like
( 510 ) 760 - 6810
astor (11-11-2011)
Old 11-11-2011, 11:32 PM   #13
RhodesHardwood's Avatar
Trade: Hardwood Floors
Rewards Points: 590
Bulldog video:
+ YouTube Video
Thats thing is nice. Never seen that before.
RhodesHardwood is offline
Old 11-11-2011, 11:50 PM   #14
Splinter hands's Avatar
Thanks PF didn't know you could replace a piece like that. I have always removed and replaced. You would just glue the new piece TO the existing then right? No glue on the floor itself, am I correct?
Splinter hands is offline
Old 11-12-2011, 12:01 AM   #15
Bulldog video:
+ YouTube Video
I think this would be the way to go, nice tool if it works like they say.
Old 11-12-2011, 09:54 AM   #16
Rewards Points: 768
I could see that coming in handy for a few situations for the initial install as well. Would like to track one of those down, find out how much it costs.
Old 11-12-2011, 05:42 PM   #17
hos's Avatar
Trade: kitchen
Yeah Tite-Bond does seem to work well with this
Birmingham Home Improvement
hos is offline
Old 11-12-2011, 06:02 PM   #18
Tech Geek
WarriorWithWood's Avatar
Trade: Remodeling Guru
Rewards Points: 1,342
http://www.torlys.com/installation/bulldog
-Dennis
WarriorWithWood is offline
Old 11-12-2011, 06:43 PM   #19
Rewards Points: 768
Thanks Dennis. I didn't see the "find stores" on that page earlier. Appears I'll be visiting one of the local carpet stores here and see how much they want to order one.
Old 11-12-2011, 08:43 PM   #20
Question
So I've fallen for this tool by far and cannot wait to get my hands on one!!! I do have few questions, One does the board replacement that was demonstrated always go as smooth? Does the furniture need to be moved? I did notice the carpet display but he didn't really work the floor in that direction. Also the web site says-
One Tool - Many Uses
Replace flooring planks in center of a room, without cutting.
Close open floor joint gaps.
Install end pieces cut on an angle.
Fix sub-floor hollow spots.
Easier access to underlayment.
Easily check floor perimeter expansion gaps.
My question is what is a sub-floor hollow spot? I almost feel ignorant in asking this one as I feel I should already know but I don't and would like to know. My guess would be rotten subfloor but seems to me that if that was the case the laminate would be damaged as well?
Any tips to start offering exotic hardwood decks MikeGC Decks & Fencing 5 09-30-2010 11:05 AM
Hardwood Parallel Over Shiplap Subfloor? seattlealex Flooring 4 05-24-2010 12:11 PM
Knockdown Texture Patch - Flashing? mseneker Drywall 7 05-18-2009 11:47 AM
Price to install real hardwood flooring and remove carpet Handyman4u Flooring 15 02-21-2009 08:36 PM
Re-using Hardwood J-Peffer Flooring 7 09-28-2008 12:50 AM
