Pergo Laminate
Old 03-05-2007, 11:25 AM   #41
dnebout's Avatar
Trade: Developer
Re: Pergo Laminate
It's been awhile but here goes. If you did it yourself call the company that you bought it from and they will get a hold of Pergo. Pergo will send out a 3rd party inspector to verify that the floor was installed properly. He'll ask you about the underlayment used as well as your leveling procedure. He'll take a probe and chck the clearance from the floor to the wall under your baseboards. He'll take a 10' staright edge and make sure that you aren't over a 1/4" out in the low and high spots. He'll ask you about your installation procedure. If everything checks out Ok, he'll give you a letter stating that you are in need of a new floor under warranty. If you did it, they'll only pay about $1.00 to a $1.50 a sq ft to reinstall and send you the new material for free. You'll have to fight them for more money. If you had the work done, they will pay the contractor to do it. You can also get a dump fee and a budget included for tear out as well as baseboard replacent. They will also send you putty,all your nosing and trim pieces. You will also get there top of the line silent floor underlayment if you don't already have it.
There was a defect in that floor. When I received the new floor there was much more wax on the tongue side of the plank. It also was a little looser fit to allow for flex withought making any noise.
Good Luck!!
dnebout is offline
Old 03-08-2007, 11:16 PM   #42
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
Re: Pergo Laminate
I am not a big fan of Pergo because of the issues. But you can't say they don't do a good job at refunding.
It's amazing how they stay in business really.
Maybe that's why they still do not have a rep up here.
Floorwizard is offline
Old 03-11-2007, 12:01 AM   #43
A2Z's Avatar
Trade: Home Improvements
Re: Pergo Laminate
Originally Posted by RichSmith1 View Post
I find that those cheap $1 laminates without the backing have more sound to them than 8mm and thicker. Customers always wanna save a buck though and it honestly aint worth it. With that 6mm crap with no padding/foam I end up trashing 1/2 of it cause it chips the edges as soon as you remove them from the box.
The kind with some backing on it already is the best way to go to reduce noise, cracking and damage of the peices.
I put that cheap $1 lam down in my house w/o the backing and don't have any complaints..The only reason I did it was because of the kids dog etc. I put the padding down over a slab..IMO if you make sure everything is tight you won't get any crackln noises..I have a job next week installing lam with the backing on it in addition the lady wants me to put down the padding too..I hope it doesn't cause problems fingers crossed!
A2Z is offline
Old 03-11-2007, 09:39 AM   #44
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Re: Pergo Laminate
It can cause the joints to seperate and the locking system to fail from too much deflection. I would explain that to her. The manufacturer WILL NOT warranty that installation...why should you?
Precision Flooring
(772) 237-9900
PrecisionFloors is offline
Old 03-11-2007, 01:40 PM   #45
A2Z's Avatar
Re: Pergo Laminate
Thanks for the tip..apparently she had it done in her other rooms I will def. let her know though..I'm not warrantying it at all she picked up all the supplies...But since her husband is a Sheriff and my next door neighbor I'll probably have to make good on the installation..I'm surprised they didn't tell her before hand...
A2Z is offline
Old 03-12-2007, 10:55 PM   #46
Flooring Guru
Re: Pergo Laminate
no doubt!
Getting laminate under door casing and jambs Blackhawk Flooring 6 01-02-2008 04:14 PM
Miter Joints In Laminate Flooring ?? AL MURZYN Flooring 6 12-27-2006 10:15 PM
Laminate Floor Richard Flooring 15 12-22-2006 12:59 PM
Tile or Laminate jwaldman97 Flooring 15 10-14-2006 06:41 AM
Tiling transition to pergo kpikul Flooring 3 09-14-2006 09:43 AM
