Trade: Developer
Pergo Laminate
I recently installed that new pergo product called Vintage Home Traditional. It's a click together floor that has 3 random lenghth boards 3.5 inches or so wide. It's beveled on all four sides and has a wood grain texture to it as well as highlights in the grain and the bevel. It's an awsome looking floor and I'm real happy with it, but it crackles when walked on. The floors were leveled both concrete and wood substrates. Pergo pad put in. Supplier told me taht it would settle in 6 months but it has not. It crackles when walked on at all times and temperatures, near baseboards or in the field. Don't know what's up!!! Any ideas!!!
Trade: Home Improvement/ Handyman Services
Re: Pergo Laminate
How and what did you use to level the floor with ??
I have had a laminate wood floor in my kitchen for a few years. If I remember correctly, (Although mine not pergo, similar product) the sub-floor can not be off by more than 1/16 of an inch over a 3ft radius. I was having a crackling sound as well. found a spot in the floor that was off by more than 1/16. That (IMO) would be the biggest reason for the crackling. In addition, are all boards together correctly??? Perhaps someone else on the this site can give you more info. Also, the crackling could be from buckeling. Is there expansion room around the perimeter of the floor, ( not butt up against the wall) ???
A bad day on the water is better than a good day at work ! BASSMASTER Last edited by bassmaster; 02-10-2006 at 07:16 PM. |
Re: Pergo Laminate
I don't know much at all about Pergo, - - but 'til someone more knowledgeable on it comes along (and they will), - - sounds to me like it was milled wrong, - - and the Pergo rep's answer is the one he's gettin' paid for. Make Pergo make good for it.
http://www.tr-built.com |
Re: Pergo Laminate
Oh, sorry Bass, - - didn't see your answer til I was done with mine.
Re: Pergo Laminate
OK tom, I thought for sure you would have a better answer than me.
A bad day on the water is better than a good day at work ! BASSMASTER |
Re: Pergo Laminate
Nah, - - actually I don't have anything in particular against it, - - but it just seems most of my customers want the real deal. I've never once been even asked to install Pergo or similar.
Re: Pergo Laminate
Ya, neither do I have anything against it. . Although I am just a little guy in the big construction world, (i.e. no employees, little jobs only) I have only had 1request in 3-yrs to put one in and never did get the job.
I liked it for myself at the time because the wife changes her decorating needs about 1x a year.. Laminate, in easy-- out easy, change the style.
A bad day on the water is better than a good day at work ! BASSMASTER Last edited by bassmaster; 02-10-2006 at 07:53 PM. |
Trade: Developer
Re: Pergo Laminate
It certainly has more variations than 1/16 in 3 ft. but my neighbor who does it for a living helped me out and said it would be fine. We sanded down the high spots and filled in the low spots with self stick vinyl tiles. He's been at it 20 + years. I think that our worst spot is probably 3/16 in 3 feet. The whole floor crackles. I know that in the 1200 sq ft we installed there has to be plenty of perfect spots.
Anyway my initial conclusion is that it's milled wrong. I called the supplier again today and they're sending out an independent inspector to check it out. I'll let you know. It won't be for a couple of weeks. Thanks for the input! |
Flooring Guru
Trade: Sales Manager
Re: Pergo Laminate
Tons of complaints about laminate crackling.
the cheaper stuff is always the culprit.
------------------------ "in 20 years you will regret more what you did not do than what you did" |
#10 | |
Re: Pergo LaminateQuote:
Good luck
Trade: Builder/Remodeler- Master Electrician
Re: Pergo Laminate
I just installed a Quality Craft floor. Random length and bevelled four sides. Sound like a match. I have some, but very little cracking? I can assure you with mine being a pier and beam home on the side of a hill I do and will have significant deflections? So far so good but it was a concern and I have been warned of the tongues breaking after months if it is too bad??
www.copusconstruction.com www.etexasrentals.com www.thelakevoice.com AkA Richard Cranium |
"da Whale don't hesitate"
Trade: Hard Surface Flooring
Re: Pergo Laminate
There is also a possibility of it being too tight. It only has to be bound up a hair bit. I would suggest popping off all the quarter round and look for tight spots. especially near corners or areas the floor wraps around something. If no luck there take a dental pick and check for clearance at all door jambs. Have you EVER put any kind of wax or finish on the floor? If so that is your problem. As far as flatness of the substrate I believe 1/4" in 10ft is tolerance. If all of that fails to explain it for you, stay on Pergo's arse and get it replaced.
#13 | |
Trade: Developer
#14 | |
Trade: Developer
I do understand your point about the pier and beam foundation being way more susceptable to movement and flexing, but it just isn't the case here. Thanks for the idea. |
#15 | |
Trade: Developer
Another idea that my neighbor had was to put down talcomb powder, which i understand is an old flooring trick. The only problem with that is the residue getting stuck in the bevel. Do you know of a clear product that I can sweep into the joints? |
#16 | |
Flooring Guru
The one you purchased is in the lower grade. Pergo makes higher grades as well. We all have a budget
Trade: Developer
Re: Pergo Laminate
I was of the opinion that this was one of Pergo's top products. "The Vintage Home Series" Are you sure?
#18 |
Flooring Guru
Re: Pergo Laminate
Vintage home is found at the big box store's yea?
they do not carry top of the line. Pergo Select is a better product. But don't let me worry you. Alot of consumers do not have top of the line and are happy.
#19 |
Trade: Developer
Re: Pergo Laminate
I just got off the phone with the supplier of the floor and the Vintage Home Traditional Strip is Pergo's top of the line product. The Select product is a couple of grades below. Everybody wanted $4.79 a foot for that floor and I got this wholesale through a flooring supply house at $3.69 a foot.
#20 |
Chief Toilet Mover
Trade: Bathroom Remodeling
Re: Pergo Laminate
Not to side track the issue, but through my flooring wholesaler ProSource I get prefinished 3/4 hardwood for that price. That seems like a lot of money to pay for a laminate floor when hardwood can be bought for the same price.
| Getting laminate under door casing and jambs | Blackhawk | Flooring | 6 | 01-02-2008 04:14 PM |
| Miter Joints In Laminate Flooring ?? | AL MURZYN | Flooring | 6 | 12-27-2006 10:15 PM |
| Laminate Floor | Richard | Flooring | 15 | 12-22-2006 12:59 PM |
| Tile or Laminate | jwaldman97 | Flooring | 15 | 10-14-2006 06:41 AM |
| Tiling transition to pergo | kpikul | Flooring | 3 | 09-14-2006 09:43 AM |
