Painter's Tape On A Wood Floor
Old 08-06-2009, 12:50 PM   #1
HomerJ's Avatar
Trade: Remodeling Specialist - General Contractor
One of my guys used painter's tape to hold down the rosin paper in an area where he was working and the customer is claiming that the finish came up when they pulled the tape up.
The tape has been down for 2 weeks. (waiting on material to finish), not in direct sunlight.
Has anyone ever experienced this?
Will it help to dampen the tape in the other room before we remove it?
Any recommendations on how this could be touched up, or am I paying to have this guy's floor refinished?
HomerJ is offline
Old 08-06-2009, 01:02 PM   #2
the big 12 inch's Avatar
Trade: hardwood floor contractor 28 yrs.
Re: Painter's Tape On A Wood Floor
I never heard of blue painters tape doing this.Sometimes if the finish is new water based poly it will come up..You should always tape the paper to paper,not the floor...I'm sure it can be resolved without refinishing the floors...
the big 12 inch is offline
Old 08-06-2009, 01:16 PM   #3
HomerJ's Avatar
Thanks for the insight. I've never seen it either, but I thought it might be because the tape was down for too long.
I'm going to see it in person this afternoon. What would you try? A cleaner? If so, which one?
HomerJ is offline
Old 08-06-2009, 09:27 PM   #4
Knowledge Factory
Floordude's Avatar
They say it can happen.
I know if you leave it on prefinished for a long time like that, it can jack with the finish, just where the tape resin was.
If it pulled the finish, chances are there was a bond issue to begin with that it just so happened your guy exposed.
Now you get to do it right, on your dime.
Sorry, but that is just how it goes.
Never tape to the finished floor and leave the tape longer than 2 days.
http://www.AustinFloorguy.com
Floordude is offline
Old 08-06-2009, 10:12 PM   #5
finaltouchfloor's Avatar
Trade: Flooring & Remodeling
Most hardwood manufacturers say don't leave it on for over 24hrs. Was it blue tape or regular?
If this a sand n finish job , yes , you already had bonding issues. What grit did you sand with? Was it over 100 grit ?
I've seen it happen on T-molds and lousy Bruce seconds.
finaltouchfloor is offline
Old 08-06-2009, 10:28 PM   #6
HomerJ's Avatar
The home has original hardwood from the 50's. We didn't do the floor, we were working inside on other things and put the rosin paper down to protect the wood floor. Not sure when it was last finished. HO says a few years ago.
The tape used was 3M blue tape for delicate surfaces. 3M says it can stay in place for up to 60 days. They say the regular blue tape isn't recommended for wood floors, but can stay in place for 14 days.
They suggested heating the rest of the tape that's still down with a hair dryer and peeling it back. We'll see if that works.
Thanks for the feedback.
HomerJ is offline
Old 08-07-2009, 12:32 PM   #7
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
There are different types and qualities of blue tape. 3M 2090 is the only one actually specifically recommended by wood flooring manufacturers iirc. I have also learned the hard way that using the cheap stuff can lead to finish issues.
Wow just saw 3M was used. Ok bad luck got ya I guess. That sucks.
Use the opportunity to point out the poor finish on the floor and sell them on a re-finish
Precision Flooring
(772) 237-9900
PrecisionFloors is offline
Old 08-07-2009, 02:57 PM   #8
mikeswoods's Avatar
Trade: interior remodeling
xylene (goof off) is a gentle way to remove any tape residue. Minwax Wipe on Poly may save a refinish job. I always keep a can in the truck . good luck
mikeswoods is offline
Old 08-07-2009, 03:02 PM   #9
DavidC
DavidC's Avatar
You can try Oops! or GooGone if its a tape residue left behind. They have saved our can a few times. What ever you try, do a test spot where it is likely to go unnoticed just in case.
Good Luck
www.CookContractingLLC.com
DavidC is offline
Old 08-07-2009, 03:31 PM   #10
The Old Master
Plumber_Bill's Avatar
Trade: Plumbing & Heating
That happened to me in my own house.
Kitchen redo and granite tops. I put down a runway using rosen paper.
Held the paper down with Blue Tape.
Down 2 weeks pulled the finish when removed, but only where the tape
was walked on.
Have photos if anybody wants to see.
Bill Parr L.M.P. www.parrsplumbing.com
This and That
for a job that's up to "PAR"
Plumber_Bill is offline
Old 08-12-2009, 09:37 PM   #11
HomerJ's Avatar
We pulled the remaining tape after heating it for a few seconds with a hair dryer. It worked like a charm, so the problem is really now in just one room.
The tape line in that room is still highly visible after cleaning with various citrus based cleaners.
In one area, I tested the wipe on poly, but it still doesn't look great after 1 coat. I used a little steel wool first, but maybe I didn't go deep enough.
I'm going to try a palm sander with 220 grit paper next. If that fails, the whole floor may need to be sanded.
HomerJ is offline
Old 08-13-2009, 03:28 PM   #12
ian @antex western
ian@prosource's Avatar
Trade: flooring
Chances are the tape line you can see is adhesive residue that now has dirt/dust stuck to it,
Try using a adhesive remover rather than just a 'normal' cleaner, remember to try a test area first to check you do not damage the floor finish.
ian@prosource is offline
Old 08-13-2009, 04:18 PM   #13
Mellison's Avatar
Trade: Home Improvement General Contractor
Do they use a floor wax?
I have heard of the tape lifting floor wax but never a finish years after application.
"Enjoy Every Sandwich" Warren Zevon
Mellison is offline
Finish on a wood floor Aggie67 Flooring 13 06-28-2010 12:21 AM
Wood Floor Article Needed onlinehandyman Flooring 10 02-07-2009 07:43 AM
Wood Floor Finisher Cdat Help Wanted or Looking For Work 0 05-13-2008 06:36 AM
Tape will not stick to travertine sealed floor DeanV Painting & Finish Work 0 01-21-2008 09:29 PM
2 x 4 wood floor trusses- Help sawit General Discussion 12 07-20-2007 10:55 PM
