Trade: Commercial property maintenance, and...
Paint On Concrete - Grinding Or Blasting?
I am trying desperately to remove mulitple coats of latex paint from slightly uneven concrete floors in order to seal it with a clear sealer (i.e. concrete must look good after). Tried a floor scraping EDCO, tried a bead blaster(too much maintenance & production rate was too slow), and the only thing that worked quickly and efficiently was a hand grinder with a diamond wheel. The problem is in production time and equipment maintenance time. I have 50,000 sq ft to do on the first job. It is also a dust free environment in halls that are 5 feet wide and sharp right angle turns - riding shot blaster can not be used...
Ken Santell Owner - Minuteman Building Services, LLC Houston, TX H: 281-955-2374 C: 281-793-1935 Vision: Creating legendary customer experiences one business, one employee at a time. Value: When you work, do it right, do it well, make it fun, be proud of it, and pass it on! Motto: If we can't improve your business, we won't ask for it. |
Trade: Mold Remediator, Decorative Concrete, Bamboo Fencing,
Re: Paint On Concrete - Grinding Or Blasting?
Buffer and water will take it up. I use this and it works.
IAQM
www.iaqm.com Elite Concrete Finishing www.eliteconcretefinishing.com Elite Bamboo Products www.elitebambooproducts.com |
Back from the dead...
Trade: Paperhanger/Painter
Chemical stripper?
I have used Stripeez ( I think that is the name) It is a great product. It will pull up mostly everything.
IAQM
Could always try buffing in gasoline with a steel-wool pad...........hehehe...made you look.
I admit...I don't know everything...but don't tell my kids I told you.
Just couldn't help my self...I'm a redneck floorman at heart.
Trade: Decorative Concrete Contractor
Minuteman, there is an excellent stripping product made by a company named Franmar.....the product is called "Bean-a-doo". It is also enviromentally safe because it is a soy based product.
I've used it on several projects where I had to remove "mastic" off concrete ! |
Trade: Service Contractor
I would go the chemical route as well. "Bean-a-doo" is a good choice.
| Concrete paint or stain? | cjc | Painting & Finish Work | 4 | 08-06-2007 10:12 PM |
| blistering paint | GWHRsuperhero | Painting & Finish Work | 9 | 03-06-2007 08:43 PM |
| Grinding concrete | InterlockPavers | Masonry | 11 | 06-26-2006 07:16 AM |
| Remove paint before adding more concrete? | reveivl | Construction | 4 | 03-26-2006 08:48 PM |
| Dealing with flaking paint....help!!!! | Zeebo | Painting & Finish Work | 9 | 11-28-2005 11:03 PM |
