#21 | |
Re: One For The CTile ExpertsQuote:
![]() But he doesn't have to go over there, the correct solution was given here. ![]() And it has nothing to do with how much money the client has to spend, it has to do with doing the job properly, not putting a "band aid" on on it, collect the money and leave the client looking for another solution to the same problem in a couple years. I try to protect my customers by educating them on what the proper fix would be, and why it must be done in a particular way. Explain all the options to them, and let them make the decision. If the customer decides to take a short cut they can use someone else. There is a right way and a wrong way to do things, not much in between. ![]() Tom |
#22 | |
The shame about (other people) ankle-biting, - - is that all the other people on site (and lurkers, too) don't get to hear ALL the options, - - and then make their own choices.
http://www.tr-built.com |
#23 | |
There is a 'fix' for this very problem, - - because not everyone knows it doesn't mean it doesn't exist. Of course, - - as is the case in any construction-related problem, - - ripping it out and starting over would always be the easier way, - - but then again, - - if 'that' is an option, - - then there was never a 'problem' to begin with, now was there??
#24 | |
Maybe if you'd read-before-you-react a little more, - - you'd be able to steer clear of these 'squabbles', - - or in your case, - - 'squibbles'.
#25 | |
I think your low-brain-cell-count is 'self-leveling'.
#26 |
Trade: membranes and shower products
as a leading mfg. of crack isolation membranes , working for many years on the task force for ANSI 118.12 standards . ( crack isolation membranes) ..I pick answer # 3..
#27 | |
Not sure anyone here recommended a 'crack isolation membrane' though, - - I'll have to check back to be sure.
#28 |
Oh, - - just R&D, - - that explains it.
#29 |
Tom you should re -read the TCA handbook and the ANSI standards.
YOU DO HAVE THEM DON'T YOU? |
#30 |
No thanks, - - that might cause me to have nightmares that even my customers don't have!!
| Sny moen experts here? 3320 vs. 3330 ?? | national | Plumbing | 6 | 04-27-2007 08:02 PM |
| thought I'd ask the experts, need advice | Unregistered | Roofing | 14 | 10-14-2005 12:04 AM |
| Test for u Experts | adams,b | Flooring | 10 | 09-04-2005 11:58 AM |
| OK A/C experts how bout this. | metalroofer | HVAC | 2 | 04-29-2005 08:21 AM |
| Seek the Advice of the Experts | kah1593 | Painting & Finish Work | 2 | 12-06-2004 07:03 PM |
