Old Flooring
Old 03-12-2005, 05:31 PM   #1
kathyh's Avatar
Old Flooring
I have really old vinyl tile on terrazzo. I have tried to scrape, use a blow torch. Nothing is removing this very well. Is there a safe chemical to use or is my only option to put ceramic tile over it?
kathyh is offline
Old 03-12-2005, 08:28 PM   #2
Flooring Guru
Floorwizard's Avatar
Trade: Sales Manager
Re: Old Flooring
if you are going ceramic tile, then it may be best to remove everything, then install new concrete board.
chip out the terazzo would be my guess, and take the vinyl with it.
Floorwizard is offline
Old 03-12-2005, 08:55 PM   #3
Teetorbilt's Avatar
Re: Old Flooring
Flor, have you ever dealt with terazzo? That stuff is harder than a whore's heart. It's also making a comeback now and is really expensive to install. If it were me, I'd clean up the terazzo and keep it, better than tile anyday.
Teetorbilt is offline
Old 03-13-2005, 12:04 AM   #4
Flooring Guru
Re: Old Flooring
AH...I see.
I guess Terazzo it is.
Or a floating floor over it.
Old 03-13-2005, 02:22 AM   #5
Teetorbilt's Avatar
Re: Old Flooring
Floating floor would cover the whole mess. I grew up with terazzo floors and they are now back in vogue, why not attempt to restore the old floor?
Be carefull though, you are dealing with marble and you don't know how well it was sealed prior to the vinyl. Solvents may cause the adhesive to migrate.
Old 03-14-2005, 07:51 AM   #6
kathyh's Avatar
Re: Old Flooring
I was thinking of staying with the terazzo, but how do I get rid the old vinyl?
It has to be there for at least the last 35 years.
kathyh is offline
Old 03-14-2005, 08:39 AM   #7
Teetorbilt's Avatar
Re: Old Flooring
Did you use a floor scraper?
Old 03-14-2005, 12:22 PM   #8
kathyh's Avatar
Re: Old Flooring
Only a maunual scraper. Will a construction grade harm the terrazzo?
kathyh is offline
Hardwood Flooring - First Go at It DecksEtc Flooring 56 10-05-2006 01:41 PM
General flooring issues Atricaudatus Flooring 3 05-29-2006 04:10 PM
Question about floating wood flooring zoner11 Flooring 10 01-17-2006 05:04 PM
Re-claimed Vertical grain fir Flooring Coop Flooring 5 11-13-2005 08:49 PM
Laminate Flooring Gina Flooring 9 04-28-2004 12:06 AM
