Oak Stair Refinishing Job
Old 08-08-2005, 10:02 PM   #21
Teetorbilt's Avatar
Re: Oak Stair Refinishing Job
Marco may have gone a little over the top but he knows of what he speaks. I can put my hand on one of those scrapers just about anywhere, sharpening and burnishing them is truly an art. I'll put one up against sandpaper anyday and you'll eat my 'no dust'.
They also cut the surface of the wood, not scratch it like sandpaper. Ask any fine woodworker.
Albert Einstein
Teetorbilt is offline
Old 08-09-2005, 10:56 AM   #22
Painting Contractor
Humble Abode's Avatar
Trade: Painting Contractor
Send a message via AIM to Humble Abode
I wish I knew a fine woodworker who could teach me how to use one. I would hate to practice on a customers stairs. I think I might go get a chair at a rummage sale or a peice of pine and try one out.
Just because some of us can read and write and do a little math, that doesn't mean we deserve to conquer the Universe. Kurt Vonnegut, (1922 - 2007) from the Novel 'Hocus Pocus'
The NAPP
Milwaukee Painting Contractor
Humble Abode is offline
Old 08-17-2005, 09:37 AM   #23
Donedat's Avatar
Trade: Hardwood Flooring
Send a message via MSN to Donedat
Yep, if you've ever seen a floorman's bicepts and forarms, you now know where he gets them from. You may think it is from swinging the 4 pounder all day long. That's only part of it. Scraping and hand sanding are also part of the trio. :Thumbs:
Donedat is offline
Old 08-24-2005, 11:47 PM   #24
adams,b's Avatar
Trade: hardwood floors
Edger and scraper is your quickest way to refinish old steps. I would like to see someone sand an old stair case down with a mouse, especially if it has wax. Anyway make sure you have a new file on hand, and talk the customer into painting the risers if possible....Actually I always go over the step with a palm sander and hand sand the steps for my last step. If there are spindles of some sort and it is getting stain I use the mouse to make everything finished with the same grit.
adams,b is offline
Old 08-25-2005, 08:49 PM   #25
Donedat's Avatar
If the treads are thick with gooey wax or old paint or even both, you can use a heat gun along with a sharp puddy knife to get the slop off. Then proceed to sanding with the edger, scraping the corners with the razor sharp paint scraper and then hand sand everything to a uniform sheen. Usually, you need only to handsand up to 100 or 120. That is sufficient cause you want the color to match the floor. If you sand too fine or too course it will effect the color in contrast to the floor...sometimes drastic contrast.
Donedat is offline
Old 09-03-2005, 03:36 AM   #26
Grainywood's Avatar
Trade: Flooring Contractor
Originally Posted by Marco
Nobody knows how to use a scraper anymore??? sheesh. Edger and a sharp scraper will whip those out faster than all the gadgets, although I'm going to buy a random orbital just to try. I have resorted to a belt sander on the risers once in awhile. Still have to scrape and handsand anyway....
Ditto. I refinished stained stairs a few months ago. You can use an edger to do the main area of the tread. Then a scraper to get at the corners and edges. I also use the Bosch Detail/Corner Sander which is nice for getting the areas sanded smooth after the scraper. Fein makes a nice random orbital sander. I got the six inch but I think a smaller sander would be better so you can use it to get at the risers as well. But the Fein is really great for getting edger marks out before staining a floor.
Grainywood is offline
Old 09-03-2005, 03:41 AM   #27
adams,b's Avatar
Right On. Sometimes with a dark stain the little orbital sanders leave "fish eyes", so I like to hand sand them to finish them up.
adams,b is offline
Old 09-04-2005, 11:49 AM   #28
Donedat's Avatar
Good eyes :Thumbs: Lot of guys can't see the difference. I got called in to resand a job some other guy did. He used an orbital palm sander. It's not a big deal if you use an orbital over the entire floor...but in just one spot?...it will stick out like a sore thumb.
Donedat is offline
Old 09-12-2005, 10:37 PM   #29
adams,b's Avatar
I have two stair cases going right now and they are both getting dark stain. Sound like fun, huh?
adams,b is offline
Old 09-25-2005, 09:50 PM   #30
Donedat's Avatar
Sorry, I'm late to post. How'd they turn out?
I admit...I don't know everything...but don't tell my kids I told you.
Donedat is offline
Old 09-25-2005, 11:29 PM   #31
Painting Contractor
We didn't get the job. Not that we got out bid or under bid, the customer wasn't expecting stairs to be so expensive to refinish. I think they put it off for a year or so. We may get it yet, as they are one of our more loyal customers.
The NAPP
Old 03-19-2011, 05:18 PM   #32
parquetselvon's Avatar
Trade: Flooring Installer
Send a message via Skype™ to parquetselvon
Here in Belgium,
There ia a Flooring company who scrap oak timber flooring without sanding. Well it's 400 to 500 euros m² ( 10 sq. ft). A guy overthere tought me how to sharpened the scraper. I made one with a pièce band saw (blue iron), it works well. I am new in this forum. I am reading old threads and I do not know if I can still respond concerning 2005 threads.
parquetselvon is offline
Old 03-19-2011, 05:40 PM   #33
Best way to renovate stair case. Steps and counter steps.
Elan edge sander Laegler ( + - 10kg) 22 pounds.
Metabo grinder with a speed variator
Support for scratch sand paper 125mm diametre
Paper grit for the Elan machine for steps only; grit 36 / 50 / 80 /
Orbital sander metabo or Festool kapex / grit 80 / 100
Countersteps must be realized with the grinder ( adjusting the speed)
Face mask (3M)
grit / 36 / 50 / 80 / 100
small orbital sander Festool 80 / 100
For corner, use a support for scratch paper diametre 50mm with a 60 /80 grits.
As I hate sharpening scrapers, I prefer using the 50mm diameter scratch support, there is only about a + - 25mm triangle left in corners, just use a chisel 30mm width, weel sharpened and just cut the corners. The chisel is easier to sharpened than the scrapers.
For each stairs / 120cm width for my quotes I will forecast a quantity
3 grit 16 sometimes / 3 x36grits / 3 x 50 grits / 3 x 80 / 3x 100 and the same for the counterstep in 125mm diametre.
I use 4 grinder (metabo) after one counterstep, I will use a second one an so on. I hate doing stair case before. Since I put this technics, even my guys tell me that ti's awesome. When I will be used on this forum, I will put some photographs. You can see a staircase by typing parquetselvon in google search. Regards.
Old 03-19-2011, 05:49 PM   #34
Since I hate renovating staircases. I give prices in a way not to have the job. I got a job for April 2011. I quoted 100 euros per steps + 150 euros per countersteps. quantity 32 steps 31 countersteps. Total job 7850 euros.
I will be doing this job myself. Charging these prices I cannot do the job in 5 days. I will do it at my ease.
Old 03-19-2011, 05:50 PM   #35
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Face mask (3M)
Where the hell were you 6 years ago Pretty sure this one is done....might be ready to do again
Precision Flooring
(772) 237-9900
PrecisionFloors is online now
The Following User Says Thank You to PrecisionFloors For This Useful Post:
pinwheel (03-20-2011)
Old 03-19-2011, 06:31 PM   #36
nymasterfloors's Avatar
Trade: Flooring
If you really want to do it yourself use an edger and A hand scraper. Scrapers are sold @ wood flooring stores that usually sell poly and what not.I do not recommend if you do not have any experience with doing treads to do it yourself. Sub it out usual cost is $25 per step.
Money is evil Family is life Love conquers all
nymasterfloors is offline
Old 03-20-2011, 09:54 AM   #37
jamestrd's Avatar
Trade: wood flooring
7850 euros?...wow..thats big money and you got it?
if you dont want the job, why show up for the estimate?
alot of work to go there to NOT get the job...
James Hernandez
Flortec flortecjh@gmail.com
New Jersey
www.flortechardwood.net
jamestrd is offline
Old 03-20-2011, 03:40 PM   #38
I do hate doing it, but if the money is there, Whom am I to spit on it !
Old 03-20-2011, 05:08 PM   #39
jamestrd's Avatar
at that rate, i would do this all week..be done in 2-3 days..make myself 16,000 a week..
would be real nice..
James Hernandez
New Jersey
jamestrd is offline
The Following User Says Thank You to jamestrd For This Useful Post:
msv (03-23-2011)
Old 03-20-2011, 11:11 PM   #40
DO IT RIGHT
the rock's Avatar
Trade: hard surface/carpentry/plumbing/electrical
Send a message via Yahoo to the rock
This scraper youguys are talking about........... are they all cordless ? or do some plug in ? lol
the rock is offline
The Following User Says Thank You to the rock For This Useful Post:
msv (03-23-2011)
Stair Jig RISENRUN Tools & Equipment 7 02-08-2010 08:30 PM
Stair Designer hatchet Carpentry 10 01-18-2009 08:14 AM
Update on my refinishing job.. ruskent Flooring 1 02-25-2007 08:48 PM
Stair case installation fuglala Carpentry 0 02-06-2007 09:51 PM
Refinishing Floors J DoubleD FLoor Flooring 6 07-26-2006 10:00 PM
