Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Flooring
Old 05-19-2009, 03:44 PM   #1
Trade: Home Improvement Contractor
Oak Plank floor putty/caulk?
I have a random width oak plank floor in a kitchen. Between some boards there are spaces from contraction. What is the best material to fill these voids. They range from 1/32-1/16th.
gzec is offline   Reply With Quote
Old 05-19-2009, 03:52 PM   #2
Trade: Remodeling general
bacon grease and sawdust helps with the squeaking too
naptown CR is offline   Reply With Quote
Old 05-19-2009, 05:29 PM   #3
Knowledge Factory
Floordude's Avatar
Fill it with humidity.
http://www.AustinFloorguy.com
Floordude is offline   Reply With Quote
Old 05-19-2009, 06:20 PM   #4
Trade: Residential remodel
Generally its done when its being finished, now i don't know maybe some colored putty?
rjconstructs is offline   Reply With Quote
Old 05-21-2009, 07:15 AM   #5
Great answers, glad I came here. You are flooring experts?
Old 05-21-2009, 07:17 AM   #6
Trade: GC/Remodeling
You are contractor?
Originally Posted by jeremy-lvhm View Post
...just stop it. go sit down and have a lollipop and think about what your saying.
TimelessQuality is offline   Reply With Quote
Old 05-21-2009, 10:04 AM   #7
Yea, why does that matter?
Old 05-21-2009, 10:21 AM   #8
Knowledge Factory
Floordude's Avatar
Oak PLANK...
We are coming out of the heating season!!!
1/32 and 1/16. Those could all close up, come late spring and summer.
If you fill them, summer swelling will push all the filler right out of the joints. Enough to cut your bare feet on.
The Following User Says Thank You to Floordude For This Useful Post:
the big 12 inch (05-21-2009)
Old 05-21-2009, 08:59 PM   #9
Trade: Flooring Industry - NOFMA Grad
Planks show the most expansion of any woodfloor. Heat in the home in the winter will shrink it, Air conditioning in the summer will shrink it. I would try to keep your home around 55% relative humidity at all times or just live with the seasonal gaps. I would not fill them with anything. If you fill it with a soft puddy, this will squeeze out later and be tracked everywhere. If you fill it with somthing hard, you will risk the wood cupping, crowning or havin alot of crumling pieces come out that may scratch the surface when walking on.
Hope this helps, Ron T
mrwoodman is offline   Reply With Quote
Old 05-22-2009, 06:33 AM   #10
Thanks for the responses
Old 06-01-2009, 07:04 PM   #11
TopFloor's Avatar
Trade: Floorist
Wood expands and contracts with temperature and humidity changes. The gaps you describe seem perfectly normal. If they remain all year 'round then you could use a latex filler. Likely they will close up on their own.
TopFloor is offline   Reply With Quote
Hardie Plank Siding robertaxxe Construction 6 03-02-2009 08:37 AM
Help with hardi plank santaboleny Windows, Siding and Doors 12 02-21-2009 08:17 PM
Paint or stain on hardi plank? Jer Painting & Finish Work 23 01-31-2009 06:05 PM
20" plank to big? dkillianjr Tools & Equipment 5 09-19-2008 05:24 PM
WTB 20'-24' aluminum plank dkillianjr Contractor Swap 0 09-15-2008 04:50 PM
