Noob Threshold ?'s: Carpet To Concrete.
Old 01-25-2005, 08:09 PM   #1
4StringSlinger's Avatar
Question
Hello all,
I am trying to find a specific threshold, and I'm not having much luck...specifically, carpet to concrete.
I'm looking to cut a square just inside the loading door of my business, about 6x8. This is office-style carpet, very thin, with no padding underneath, just concrete. Basically I'm trying to find advice on where to buy, what type, and installation mode, ie, adhesive, etc.
The threshold needs to be pretty stout, as heavy equipment is loaded through this door frequently.
Thanks in advance for your help!
4StringSlinger is offline
Old 01-26-2005, 10:00 AM   #2
Don Benham's Avatar
Send a message via AIM to Don Benham
Re: Noob Threshold ?'s: Carpet To Concrete.
Originally Posted by 4StringSlinger
Hello all,
snip
Have a look at These reducers You need to decide on the exact size base on thickness of the carpet. You'll notice some styles are for carpet/nothing, carpet/VCT, sresilient/resilient, bla bla bla. It sounds as if you need the carpet to nothing style.
I always use Chemrex to install it. It's a high solids adhesive that holds like a bear. You need to mist the adhesive with water to make it cure but when it does.... when I use it for tackstrip I can powerstretch in 3 hours. And I stretch tight, it nevers lets go.
Both should be able to be found at your local flooring supply house.Check the yellow pages for "Flooring supplies and equiptment. Or something to that effect.
good luck,
Don
Benham Flooring
__________________________________________
Look, I know the voices in my head aren't real, it's just that lately they've had some really good points.
Don Benham is offline
Old 01-26-2005, 11:39 AM   #3
Thanks a million, Don.
My main concern was what type of adhesive to use...sounds like good stuff.
Once again, thanks!
Fiber Optics in concrete countertops 6stringmason Concrete & Paving 17 03-16-2011 05:49 PM
Staining concrete ryan.s Masonry 12 03-05-2009 03:54 PM
structural concrete... mdshunk Masonry 3 03-05-2009 03:42 PM
Carpet Removal on Concrete trichar7@maine. Flooring 6 04-16-2008 03:21 PM
New to carpet tile J&J Home Imp. Flooring 7 06-22-2007 07:05 PM
