No Slip Hardwood
I'm about to refinish some nice old hardwood in a fitness studio. They need it done quickly, so I'm finishing with a waterbase (satin finish). They insist that this floor must not be slippery. Will the satin finish do the trick or do you folks have any suggestions?
Cheers! Ian. |
#2 | |
Flooring Guru
Trade: Sales Manager
Re: No Slip HardwoodQuote:
![]() they could slip on any finish. it's a relative term. See if you can find the slip resistance specs on the finishes and let them pick it out. I would hate for them to have unrealistic expectations. It may cost you.
------------------------ "in 20 years you will regret more what you did not do than what you did" |
There are any number of things that you can add. First look at non-skid for boats, they are made to look classy.
Most are made by adding thixogens for resins. You can try glass bubbles or QCells for starters, bubs are smaller. These are commonly used for non-skid on high-end yachts. There are some others, you may want to check Interlux, they offer about 3 different grits.
Trade: tile contractor
use poly that is made for sport floors/gymnasiums - check with floorstyles,800-767-8953.sport poly has anti slip guidelines. justin
| Help Installing Hardwood over old/new Concrete Slab | Hages | Flooring | 7 | 06-04-2008 01:02 PM |
| Hardwood or tile in Spec House Kitchens | williefb | Kitchens & Baths | 18 | 02-19-2008 05:37 PM |
| Hardwood Flooring - First Go at It | DecksEtc | Flooring | 56 | 10-05-2006 01:41 PM |
| Hardwood over hardwood? | dkillianjr | Flooring | 9 | 09-21-2006 09:07 AM |
| Questionss on Hardwood underlayment and expansion | newtofloor | Flooring | 8 | 11-24-2005 08:18 PM |
