Haven Hardwoods
Trade: Hardwood Floor Company Owner
Newer Stick Vinyl Tile
Have you guys ever installed this newer vinyl tile (saw it at Home Depot) that is sticky on two sides. It is floating and claims to be waterproof. The sheets are a little shorter than laminate and about the same width. The ones that I saw were made to look like real wood. My buddy is going to put it down on his parent's and I was interested in trying it out as another flooring alternative for wetter areas such as bathrooms and kitchens. Anyone ever install this stuff? Good or bad? Any tips for an easier install? Thanks
Re: Newer Stick Vinyl Tile
[quote=cinder11;429792]Have you guys ever installed this newer vinyl tile (saw it at Home Depot) that is sticky on two sides.
sticky on two sides, sounds like the customer might complain, must be tough to clean
Knowledge Factory
Very temperature sensitive.
Siding Windows Doors
Trade: Exteriors
The product we saw at HD is called Traffic Master. Its suposed to be water proof.
Has any one used this product yet. |
Trade: Exteriors
We did three bathrooms with Traffic Mater Allure flooring. The product installs and looks very nice. Two floors were striped to concrete and primered and installed while one installed over an existing vinyl floor. Its warantied for 25 years but who knows. One nice thing is if a piece gets damaged you can pull it out of the floor and replace it.
tile mason
It's sticky on both sides so it'll catch flies.
Matt with Cupan Custom Tile & Paint of Lowell, Massachusetts Design and installation of ceramic tile and natural stone for floor, wall, and countertops (978) 601-8774 | cupantile@gmail.com | view tile pictures and more |
celtic
Trade: Flooring
Tiles can't be waterproof...............................
Can they???? |
Trade: Exteriors
Re: Newer Stick Vinyl Tile |
I like Green things
seen it down before, got yelled at by HO when istalling her kitchen because I said the corian counter top looked to good for that cheap ass flooring.
celtic
Trade: Flooring
What about the joints between the tiles??
The whole point of sheet vinyl is that you can weld the joints and make it waterproof. Tiles can never be waterproof. Kinda defeats the purpose. You can use a Pu or epoxy adhesive but there is the chance water ingress will still make the floor finish fail. That was a rhetorical question anyway. |
celtic
Trade: Flooring
I don't get the original point.
If a tile is indeed sticky on two sides?, how can it be termed floating? The tiles will move all over the place if it is floating. Is it similar to Amtico etc. only with adhesive on it already? What about cutting in around the perimeter, adhesive all over the ones already stuck? or is it just a tackifier. More than likely just a cheap version of Amtico et al. |
Jack of All
Trade: Remodels
The flooring itself floats... the overlapping 1" joint is sticky on both "sides".
I used some of it in a small closet/office that would be seeing alot of chair traffic. Laid down very nice... the stuff seems to be tougher than all get out. The adhesive is time sensitive.. after a couple of minutes it was everything I could do to separate the two pieces. I think it is an excellent product in small areas prone to getting wet... like entry closets, mud rooms etc. Doug |
| vinyl over vinyl? | chris n | Flooring | 14 | 02-25-2008 07:38 PM |
| Vinyl over ceramic tile? | tersh | Flooring | 15 | 02-17-2008 05:24 PM |
| Learning to install Floor and Wall Tile!! | TurnkeyConst | Flooring | 25 | 01-17-2008 08:01 PM |
| Rip up vinyl and put Tile down over OSP flooring | killzoneq2 | Ceramic & Stone Tile | 2 | 05-07-2007 09:11 AM |
| Vinyl self stick tiles question | Mike Finley | Flooring | 21 | 04-03-2006 07:56 PM |
