New Floor
Old 05-28-2004, 07:52 PM   #1
sbrown880's Avatar
Red face
New Floor
My flooring an my subfloor are the same. It was covered in carpet by the last owner. As I walk I feel gives and dips. I want to install 1/2" plywood over the flooring, minus the carpet. However when I get to the stairs the flooring is in plane with the top step. How do I finish the floor with the 1/2" ply where it meet the top tread Help and Thank you much.
sbrown880 is offline
Old 05-31-2004, 05:31 PM   #2
Don Benham's Avatar
Send a message via AIM to Don Benham
Re: New Floor
If I understand right you're upstairs dealing with the nose of the top step?
You could cut the nose back even with the top riser, and your 1/2 inch even with that, then, depending on what your new floor will be use something in this shape....
If carpet, level witht he 1/2 inch, if other use with new flooring.
g'luck
Don
Don Benham is offline
Remodel - Floor sag tmenting Framing 0 01-28-2007 06:56 PM
bouncy kitchen floor, will grout crack? kmd Ceramic & Stone Tile 3 01-26-2007 10:23 PM
Help with clear coating a hardwood floor pdiesel5 Flooring 5 11-03-2006 08:56 AM
Basement floor dilemma ron schenker Flooring 11 07-02-2006 09:36 PM
overhead poured floor landmark Masonry 6 03-03-2006 03:53 PM
