New Construction - Hardwood Flooring Advice
Old 02-22-2009, 10:31 PM   #1
simeon's Avatar
Trade: New construction
I will have to install hardwood floors in a new construction of a single storey residence in tropical climate. Construction to start in April. Which subfloor is recommended / more cost effective - concrete or wood?
simeon is offline
Old 02-22-2009, 10:48 PM   #2
Paramount Contr's Avatar
Trade: Renovations
Re: New Construction - Hardwood Flooring Advice
I would recommend a concrete wood mixture you get the best of both worlds
Paramount Contr is offline
Old 02-22-2009, 10:52 PM   #3
Snobnd's Avatar
Trade: Remodeling 30+ yrs
Say What???????? I think you mean to leave the concrete or cover it with plywood base for the wood flooring?
Snobnd is offline
Old 02-23-2009, 07:10 AM   #4
Mike Costello's Avatar
Trade: Flooring
Send a message via Yahoo to Mike Costello
He is pointing out that your question makes no sense
Mike Costello is offline
Old 02-23-2009, 07:24 AM   #5
egotistical prick
Cdat's Avatar
Trade: Wood Inlay
If you don't know, you're in the wrong forum. Have a good day...
Cdat is offline
Old 02-23-2009, 07:25 AM   #6
simeon's Avatar
The subfloor has not yet been laid and we are trying to decide whether to use a concrete subfloor or a wood subfloor i.e. joists, to install the hardwood floors throughout the house.
No decision has been made yet on what material the foundation will be made of. And of course hardwood floors can be installed on either subfloor. We are in a position to influence that decision and I wanted some advice on which would be recommended / more cost effective.
More information: the house will have concrete/brick walls throughout.
Thanks for the comments.
simeon is offline
Old 02-23-2009, 07:31 AM   #7
Pompass Ass
bwalley's Avatar
What do the plans show?
bwalley is offline
Old 02-23-2009, 07:47 AM   #8
the big 12 inch's Avatar
Trade: hardwood floor contractor 28 yrs.
Concrete is good for parkin cars on and patios-sidewalks.I can't imagine livin on the ****!!!
the big 12 inch is offline
Old 02-23-2009, 08:04 AM   #9
Pompass Ass
bwalley's Avatar
Most houses in Florida are slab on grade, it is what I am used to, so it isn't bad, when we do a hardwood floor install on a slab on grade, we will use a glue down engineered wood, or nail down 3/4" plywood and then do a nail down.
I have Marble in my house but prefer wood.
Marble is definately impressive looking, but I like the feel and look of wood better.
bwalley is offline
Old 02-23-2009, 08:14 AM   #10
simeon's Avatar
The plans currently show a concrete foundation but that reflected the client's first choice of porcelain tiles. Now they have changed their minds and want real hardwood floors (not engineered wood), so the question is whether to change the subfloor system to a wood one or stick with the concrete foundation.
simeon is offline
Old 02-23-2009, 08:25 AM   #11
We have many houses here with concrete subfloors too.Mostly lower end stuff.But iv'e seen multi million $ houses on a slab with cheap prefinished wood floors...go figure!!.Most builders pour a slab just to save $$$.
Old 02-23-2009, 08:28 AM   #12
Pompass Ass
bwalley's Avatar
In Florida slab on grade works better for more reasons than money, most house are built of block, although some are frame.
bwalley is offline
Old 02-23-2009, 08:33 AM   #13
Pompass Ass
bwalley's Avatar
Where is the house being built?
If you want to go with a solid wood nail down, I recommend using MVP, then a layer of 30lb felt with all seam overlapped 12", then nail down 3/4" T&G plywood, then nail down the hardwood, sand and finish onsite.
The foundation has nothing to do with the flooring.
Your trade says New construction, are you a contractor, or a owner/builder?
bwalley is offline
Old 02-23-2009, 09:01 AM   #14
Are you affraid of the big bad wolf?...lol..
Old 02-23-2009, 09:06 AM   #15
Pompass Ass
bwalley's Avatar
Hurricanes are 1 thing, Termites and water damage are another.
I like termites though, they put steak on my family's dinner plate.
bwalley is offline
Old 02-23-2009, 01:45 PM   #16
BRANCH MANAGER,SALES
RUSH CAMARATA's Avatar
Trade: flooring distributor
Well that depends on how much money you wont to spend.If i had the money plywood,but if i had very little money concrete.Think about moisture and what type of flooring that you want.
RUSH CAMARATA is offline
Old 02-23-2009, 10:25 PM   #17
Old school Ranger
floorinstall's Avatar
Trade: flooring
If the customer wants to use solid 3/4 inch hardwood use the plywood sub floor. It will give a broader choice of finish flooring. You can install just about any type of hardwood over plywood as long as it is on or above grade.
floorinstall is online now
Old 03-16-2009, 10:58 PM   #18
cmejio's Avatar
Trade: flooring
I would go with concrete and an engineer hardwood since it looks like it is in an area with high humidity.
cmejio is offline
I Need Career Advice tgrib General Discussion 5 08-13-2009 02:13 PM
need some flooring suggestions Farmer Boy Flooring 4 02-21-2009 07:53 PM
Company Resume...Need Some advice and suggestions nycballer31488 Marketing & Sales 7 12-03-2008 03:19 PM
Hardwood over Asbestos Tile 4yanx Flooring 10 11-08-2008 08:39 PM
NEED GUIDANCE help on Hardwood Flooring womanangler Flooring 2 09-14-2007 01:22 PM
