#21 |
Re: New Carpet Air Pockets
Dummy me, I responded to your post before reading all of it,lol.
Id totally bet your right on the fold marks. Being in New England in the winter, you should see what you can do to a 30 footer trying to bend it . You ever tried the new urethane adhesives for strip? You can power stretch off of it in about 2 hrs. |
#22 |
Professional Installation
Trade: Flooring
Absolutely correct. The thing is if you live in a humid location, the damn glue doesn't dry. Or someone doesnt want to take the time to let it dry. Also, if you are on a direct glue down, and you row cut your seams...there will be bubbles where the seam waves in and out. And, even in direct glue down you need a power stretcher to adjust your pattern if there is one.
#23 |
Trade: Flooring
If this was to me, the bubble I am talking about was about 3" off the floor that I could NOT power out even after two days of acclimation.
#24 |
It was meant to be to the origional poster.
But wholly crap! |
#25 | |
Trade: Commercial Flooring
I live in New England, and the winter is rough on residential installs, but I have an extended E-350, I can let the van run and keep the heat blasting, while I get everything ready to go. Never tried that urethane adhesive, but i will look into it. Right now I do mostly commercial work for a company, but I am gravitating back to residential work.
#26 | |
A mini stretcher with the attachments, is great for the patterned goods on direct glue downs and tack and pad, have had to use the mini and the power stretcher at the same time before. As far as they glue drying, setting, curing, as long as you have the right trowel notches, and get a good adhesive transfer to the backing, the bubbles will go away 99% of the time.
#27 |
I would bet the carpet was stored off the floor on a pallet or a piece of wood, or something, for a long period of time, and it is not so much a bubble but an indentation. The backing becomes distored, dries out, and it takes alot of effort to try to make it flatten out.
#28 |
Trade: Flooring
Its been so long, I dont remember the exact details.
As for tack strip, here in Seattle, especially West Seattle, the concrete is like iron. You can not take a 1/2" fatty or skinny to it. So we use a a glue called chem-rex. Water is the catalyst and in two hours you can stretch. Most of the time that is plenty of time to do layout, seams, and lunch before it is time to stretch. Besides, I believe that it is much better to get the job done than do nothing but glue strip and come back another day...I think the home owners agree as well.... |
#29 | |
Re: New Carpet Air PocketsQuote:
| tips on painting baseboards with carpet floor and a tip for new painters | Zeebo | Painting & Finish Work | 10 | 04-22-2011 06:42 PM |
| Baseboard trim before or after carpet | mtheisen0814 | General Discussion | 19 | 05-28-2008 09:58 PM |
| New to carpet tile | J&J Home Imp. | Flooring | 7 | 06-22-2007 07:05 PM |
| Carpet and hardwood | J DoubleD FLoor | Flooring | 7 | 09-16-2006 02:03 PM |
| installing carpet onto stairs | cynthiann | Flooring | 2 | 04-09-2006 12:08 PM |
