Need Some Flooring Suggestions
Old 02-21-2009, 09:19 AM   #1
Farmer Boy's Avatar
Trade: Custom Horse Barns
We converted an old barn into a winery. For the new floor we took out the existing 100+ year old flooring got it planed down and put a t&G on it.
then we installed two layers of 3/4" T&G plywood flooring, felt paper, double bubble insulation, and 2 x 4 sleepers with hot water floor heat between the sleepers, buried all the tubing with gyp crete and then put the original flooring back in as a hardwood floor. The flooring was attached to the sleepers with construction adhesive and hardwood floor nailers. It all looked good when it was done but now we have a problem with the stuff buckling. So i'm hoping somebody can tell me what we should have done different and maybe a good solution to fix the problem. we did give the gyp crete about 3 weeks to cure properly but it seems we're still getting some moisture.
Also we had about 4 different species of wood mixed together.Any suggestions would be appreciated.
Farmer Boy is offline
Old 02-21-2009, 10:50 AM   #2
jamestrd's Avatar
Trade: wood flooring
Re: Need Some Flooring Suggestions
if your floor is buckling , it is always water..
check the radiant system thoroughly.
secondly, if its a plank floor, it is against guidleine to install over sleepers..need plywood substrate.
as the heat came on, possibly more moisutre was expellled from the gypcrete into the flooring..
is it buckling or cupping?
you need a moisture barrier directly under the flooring.
jamestrd is offline
The Following User Says Thank You to jamestrd For This Useful Post:
Farmer Boy (03-07-2009)
Old 02-21-2009, 11:06 AM   #3
Farmer Boy's Avatar
we do not have plywood substrate or moisture barrier. and the floor is buckling and cupping. the flooring is anywhere from 4" to 8" wide. Not enough research was done before the job and it's kinda coming back to bite us. So is there a remedy or does the whole flor need to come back up.
Old 02-21-2009, 03:22 PM   #4
Knowledge Factory
Floordude's Avatar
From my monitor, I can tell you this...
The wood flooring gained moisture since it was installed.
Now for probable causes.
#1 most common cause, especially for plank flooring... Acclimation
#2 lack of a moisture barrier
#3 dew points being reached
#4 green housing, creating #3
#5 leaky pipe in foundation
#6 flood
What's the rule for concrete... 30 days per inch. Now, you have Gypcrete which is much wetter when pumped or poured. You could be looking at months before it really is dehydrated and ready for flooring.
http://www.AustinFloorguy.com
Floordude is offline
The Following 2 Users Say Thank You to Floordude For This Useful Post:
Farmer Boy (03-07-2009), sparehair (02-24-2009)
Old 02-21-2009, 07:53 PM   #5
the big 12 inch's Avatar
Trade: hardwood floor contractor 28 yrs.
You need to pull up a few boards all the way down the middle to at least take the pressure off the floor for now...
the big 12 inch is offline
The Following User Says Thank You to the big 12 inch For This Useful Post:
Hardwood flooring business. trapperj86 Business 1 02-25-2011 02:38 PM
Hello from Flooring Chick FlooringChick Introductions 40 03-19-2009 09:11 PM
Brazilian Walnut nail down flooring Monrovi Flooring 12 01-01-2009 10:13 AM
Cork Flooring Questions.... SBI Flooring 3 12-12-2008 04:18 PM
Re-claimed Vertical grain fir Flooring Coop Flooring 5 11-13-2005 08:49 PM
