Need A Little Advice On Laminate Install
Old 03-22-2008, 09:48 PM   #1
Vabuilder's Avatar
Hey guys, I'm going to be bidding on a laminate install that include a set of steps which I've never done before. I need some advice on dealing with the ballusters on the steps, currently there is carpet everywhere. should I under cut the ballusters enough to get the laminate under them and then toe nail the ballusters to the laminate ??? please give me some help with this.
thanks,
A gun in the hand is better than a Cop on the phone !!!
Vabuilder is offline
Old 03-22-2008, 10:29 PM   #2
genecarp's Avatar
Re: Need A Little Advice On Laminate Install
you should be able to remove the ballusters, then reinstall, make the customer aware that painting, will probably be required after completion. most ballusters will pop out with a little persuation.
genecarp is offline
Old 03-23-2008, 08:00 AM   #3
Knowledge Factory
Floordude's Avatar
Don't float it on the stairs!! Fully glued, and tight to the walls. Just like wood strips on steps.
http://www.AustinFloorguy.com
Floordude is offline
Old 03-23-2008, 08:16 AM   #4
orson's Avatar
Trade: Kitchen & Bath
I would try to get a baluster loose to see how it's attatched. If there are dowel screws in the balusters you are going to have a hell of a time undercutting them.
orson is offline
Old 03-23-2008, 09:15 AM   #5
GoodHouse's Avatar
Trade: Flooring
Laminate should not be on steps, particularly open ended steps with spindles such as you describe.
Laminate was never inteneded for that use. Persuade the client to change to a carpet or have sanded / finished.
GoodHouse is offline
Old 03-23-2008, 09:32 AM   #6
Vabuilder's Avatar
thanks Guys, I've been doing some research and kind of figured that laminate is not made for open ended steps. I'll talk to the customer and see where we land.
thanks again,
Old 03-23-2008, 12:05 PM   #7
THE FINISHER
lawndart's Avatar
Trade: Finish Carpenter
Send a message via AIM to lawndart
Couldn't agree more. I would walk away from the job if the customer insisted on it. Actually I have on quite a few over the past few years. Explain that their best option is to stain the steps to match closely.
lawndart is offline
Old 03-31-2008, 08:11 PM   #8
eurofloors's Avatar
Trade: Floors, marble and granite counter tops, wall coverings, etc.
Hey gusy!!! is Snap-in Synthetic Wood Flooring the same as laminate flooring?
eurofloors is offline
Old 03-31-2008, 10:00 PM   #9
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
No offense man, but you might not have the skill set required to install laminate on steps.....that doesn't mean it can't or shouldn't be done So why does Wilsonart make one piece stair treads again?? To do the job right you take the hand rails and balusters off and reinstall after the treads go down. As far as steps with returns go, thats what a scms and a router is for.
VAbuilder if you still need this done, I'm in Hampton and wouldn't mind looking the job over for you and giving you an estimate. It won't be cheap, and I couldn't get to it until mid April but the offer is there fwiw. It CAN be done, if done the right way.
Precision Flooring
(772) 237-9900
PrecisionFloors is offline
Old 03-31-2008, 10:01 PM   #10
No.
Precision Flooring
(772) 237-9900
Old 03-31-2008, 10:04 PM   #11
Learn how to accommodate your customers wants and needs and your reputation and profit margin will increase exponentially. If you tell a customer something "can't" be done because you don't know how to do it and they find out otherwise it makes you look less than professional.
Dart don't take that the wrong way....I know you are a pro and do quality work. Just throwin food for thought out there.
Precision Flooring
(772) 237-9900
Help!!!...... Advice for waste oil heater install ChicagoLawn HVAC 32 01-14-2012 10:13 PM
Wood Laminate Install Cost per Sq Ft ? ronnronn Flooring 16 12-28-2011 01:16 PM
Tile or Laminate jwaldman97 Flooring 15 10-14-2006 06:41 AM
Advice DaveK Flooring 10 10-08-2006 07:46 PM
Need advice on this crown install challenge! Richie-C Finish Carpentry 26 03-30-2006 09:58 PM
